Troubleshooting a MacDonald Am/FM/Mpx Stereo
  • Thread starter Thread starter type6
    Troubleshooting
The discussion revolves around troubleshooting an old MacDonald AM/FM/Mpx stereo receiver that is only producing mono sound, even when tuned to stations that broadcast in stereo. Participants explore potential causes and solutions related to the stereo light not illuminating and the overall functionality of the stereo decoder.
  • One participant reports that the stereo light does not come on, indicating a potential issue with the stereo decoding circuitry.
  • Another participant questions whether the light might be burnt out, suggesting a basic check.
  • Concerns are raised about the signal strength, with one participant noting that weak signals can prevent the stereo decoder from functioning properly.
  • It is mentioned that a 19kHz tone is necessary for the stereo decoding circuitry to activate, which may not be present if the signal is weak.
  • Participants discuss the importance of the antenna used, with suggestions to improve signal strength through better antenna placement or type.
  • One participant expresses frustration, stating that despite having an external antenna, the stereo does not work while other receivers do.
  • Another participant suggests that the problem could stem from various internal components, including solder joints, RF section gain, or the decoder itself.
  • There is mention of the possibility of finding loose components or overheating issues inside the unit.
  • One participant shares a resource for further information on audio equipment repair, suggesting a community for hobbyists.
Participants express differing views on the potential causes of the stereo issue, with no consensus reached on the exact problem or solution. Some focus on signal strength and antenna issues, while others consider internal component failures.
Participants note the limitations of troubleshooting without a manual or diagnostic equipment, and the discussion reflects varying levels of expertise among contributors.
Individuals interested in vintage audio equipment repair, troubleshooting stereo receivers, or those seeking community advice on similar issues may find this discussion relevant.
type6
I have a old stereo that I am repairing. Its a old MacDonald Am/FM/ Mpx. The problem is, it operating on Fm mono. Even on Mpx. I''ve checked ever thing I know of. But the Stereo light will not come on. I've read every book on it. But I can't same to find the problem.
This is probably a stupid question, but have you checked to make sure that the light isn't burnt out?
Do you actually hear stereo when the light is not on and the signal is strong enough for other receivers to work correctly? Most receivers inhibit the stereo decoder if the signal is too weak because the audible noise level is so much worse when you add the stereo difference signal.
The problem could either be with the decoder or with the RF / IF stages if it doesn't work with a good signal.
yes I have! I've checked all the capacitors. Resisters, But the sound come in . Mono, you can hear it! Compared to my other stereo I have. In fact when I tune into a station that is broad casted in stereo! I get no volts to the stereo light. Its dead! Oh well I can sell it for parts.
Without some knowledge of its internals this will be hard to fix.
When a station broadcasts in stereo there is a 19khz tone accompanying the sound signal , its job is to turn on the stereo decoding circuitry and the light.
read up on it here.
http://en.wikipedia.org/wiki/FM_broadcasting
Are you equipped to find that part of your radio's circuitry?
good luck
You still haven't made any comment about the level of signal that you are getting. This can make a big difference. An old receiver on the fringe of a service area is unlikely to work in stereo. What sort of antenna are you using? Using a simple dipole, at the top of the house can improve signal strength. No fancy engineering needed. Just separate the end of a length of coax so the inner and braid are spread out. Make it about a half wavelength, end to end. This will be a lot more effective than the whip on top of the set. Perhaps you are referring to a portable without an ext. antenna input, though - in which case get as high as you can with it - or drive to somewhere near the transmitter!
read up on it here.
good luck[/QUOTE
I know all about that! What gets me. Is I have a out side atennna
hooked up to it. It come in mono. Even on MPX . With all the channels. I tune in. Then I hooked up my Sansui. Stereo light come on. It works find. My friend is going nuts trying to find the problem. I said throw it out.
You seem to have established that it is not a limitation due to signal strength so is could be anything from a dodgy solder joint on the input connector, to the RF section gain, to the local oscillator / mixer, to the if amplifier(s) or filters, to the decoder itself. If you look inside, there is always a chance that you could find a loose component or lead - or something that looks like it has been very hot.
It could be a long job and would need a fair amount of diagnostic equipment plus a manual for the receiver (probably obtainable for free). You could buy a new receiver for not many quid - but that would be no fun.
Not worth getting into the problem really unless you plan a lifetime of equipment repair, in which case the experience could be good for you.
Its a roof antenna for radio's. I have a CB unit. It works great. For my Sansui. It just won't work for this old radio. I'll tell my friend to just junk it. The newer radio will pull in signal with just a little table top antenna.
Nope! No stereo at all! Just mono. Its a big differents when you hear stereo! Its a old radio!
There's a site "AudioKarma" where hobbyists swap information about their old stereo gear.
I found a thread on my Fisher RS1022, you might try there on your Macdonald.
  • · Replies 79 ·
  • · Replies 29 ·
  • · Replies 23 ·
  • · Replies 18 ·
11K
  • · Replies 23 ·
