Troubleshooting Bridge Rectifier in LT Spice Simulation
  • Thread starter Thread starter lukesowersby
    Bridge Rectifier
The discussion revolves around troubleshooting a bridge rectifier in an LT Spice simulation as part of a linear power supply project. Participants are addressing issues related to the expected output waveform, the relationship between DC and AC voltages, and the correct interpretation of simulation results.
  • Homework-related
  • One participant expresses confusion about obtaining a sine wave output with negative values reflected in a bridge rectifier setup.
  • Another suggests plotting the difference between rectified voltages or the voltage across the load resistor to aid in troubleshooting.
  • A participant raises a question about the relationship between Vdc and Vac, referencing a formula (Vdc = 1.41 x Vac) and expressing uncertainty about their results.
  • Some participants clarify that the formula for Vdc uses the rms voltage for Vac and does not account for diode voltage drops in the rectifier.
  • One participant proposes a method to calculate Vac based on desired Vdc and the voltage across the regulator.
  • Another suggests checking the Spice circuit to verify the relationship between the regulator input voltage and the amplitude of the transformer secondary voltage.
Participants do not reach a consensus on the correct approach to troubleshooting the simulation, as multiple viewpoints and interpretations of the formulas and results are presented.
There are limitations regarding the assumptions made about voltage readings and the specific configurations of the circuit components, which may affect the outcomes discussed.
lukesowersby
I am to build a linear power supply in four stages. However, at stage two, i have to add a bridge rectifier to the ouput of my transformer. My lecturer at university says i should get a graph that is a sine wave, with the negative values reflected into the positive x-axis (Volatage). I was wondering were am i going wrong?
2. The attempt at a solution
http://img399.imageshack.us/img399/1367/ltspice1gm7.jpg
Any help would be greatly appreciated.
Thanks.
You need to plot the difference between rectifidp and rectifidn. Or, alternatively, plot the voltage across your load resistor, R5.
Yeah, had a suspicion it might have been that, but it took me a while to work out how to enter an expression. Only started using the program a few days ago, so I'm still getting used to it.
http://img218.imageshack.us/img218/138/ltspice2rc0.jpg
Many thanks for your help.
I've got another problem. For a full wave bridge, with a capacitive filter, we are told the following relationship between Vdc [V(Regout)-V(Rectifidn)] and Vac [V(Secondary)]:
Vdc = 1.41 x Vac
However, I'm obtaining the following results:
http://img386.imageshack.us/img386/5310/lt4vr1.jpg
I'm just wondering if i have the wrong formula, or taking incorrect readings?
Thanks.
lukesowersby said:
Vdc = 1.41 x Vac
A couple of things to keep in mind here:
That formula uses the rms voltage, not the amplitude, for Vac.
Also, it does not account for the 2 diode drops in the rectifier voltage.
Ah, forgot about rms. Thanks.
That equation was given a bridge rectifier (4 diodes) with a capacitor and load resistor, but exluding the regulator. So i assume to calculate Vac, if i want Vdc of 5, i simply calculate 5+the voltage acrross the regultor, all divided by 1.41.
You can check that on your Spice circuit, "transformer1 stage 5".
If you plot
V(rectifidp) - V(rectifidn)​
and
V(secondary)​
you can see if the regulator input voltage equals the amplitude of the transformer secondary.
Yeah, thanks for your help.
13K
9K
