Troubleshooting LaTeX Installation on Laptop
In summary, a person is trying to install a LaTeX program onto their computer and is having trouble with various steps. They have tried downloading from Miktex.org but are having trouble with the installation process. They have also tried downloading from Technicenter but are having trouble with the installation process as well. Finally, they have tried to install from the installation directory that was provided by Miktex but are having trouble. They are asking for help from someone who is better acquainted with the process.
tom1985
Hi people,
I am totally crap with computers and I have tried numerous times to install a LaTeX program onto my computer and each time it doesn't seem to work, for whatever reason. There always seems to be extra files to download and I am totally lost as to what I actually need.
Could someone help me out here? Like I say, I need a fair bit of guidance due to my sheer incompetance.
I have tried downloading from Miktex.org but whenever I get to the final stages of the installation it suggests a directory for the files to go in, but then it tells me that the directory is not empty?!
HELP, PLEASE
Dr Transport said:
Try technicenter...
http://www.toolscenter.org/
I am following these guidelines: http://www.artofproblemsolving.com/LaTe ... nloads.php
When I open TeXnicCenter and it asks me for the "full path of the directory where the executables" are located, and I give it C:\Program Files\MiKTeX 2.5\miktex\bin - it comes up with an error message, even though I haven't changed the original destination when I downloaded MiKTeX.
Any ideas? I know it's probably very trivial, but you would make me a very happy man if I could finally sort this out...
Thanks in advance
doesn't cygwin have latex built in?
It's an optional package (tetex).
Even though I have cygwin, and use it extensively, I prefer MiKTeX, with its YAP previewer [which can interact nicely with text editors]. MikTeX will also prompt to find any missing files or packages on the website.
You may try PcTeX
Guys, thanks for the editor suggestions and all, but at the end of the day I can't install MikteX fully because it keeps telling me that the directory isn't empty, and since I have no clue what this means I can't go any further. Someone here must know how I can sort this?
Have you looked at http://docs.miktex.org/2.5/manual/installing.html ?
Admittedly, I've been using MikTeX 2.4... and I have had no plans to upgrade anytime soon [for fear of breaking my current setup].
Note:
http://facweb.arch.ohio-state.edu/pviton/support/tex4ht.html
suggests that "If you are doing a fresh installation of MikTeX 2.5, or you can do a re-installation, do so using the installer, but do not install to the default folder. Instead, use one which does not contain spaces: one suggestion is c:\texmf; but it’s up to you."
(MikTeX 2.4 and earlier used such a directory name.)
When TexnicCenter asks you for the path, did you just type "C:\Program Files\MiKTeX 2.5\miktex\bin" or did you search for the directory, i.e. click until you got to the folder?
I did both. I can't understand why this still won't work.
To be honest I don't really understand what I actually need for this to work.
I tried downloading proTeX, which I did. It seems that it came with miktex, so when I came to install miktex it asks me to choose the location for the installation directory (it already has miktex in there) but even when I choose the folder myself it tells me the specified directory isn't empty?! What does that even mean, aside from the fact that it's not empty?!
It would really help if someone just listed down what programs I need to download in what order, then that way I might be able to see what I am doing wrong.
Again I apologise for my abilities here, and thank you again for your input.
Note:
Ok, so i typed in c:\texmf as my installation directory, and it seems to be going ahead now...So thanks for that
I still feel like I have got no idea as to what is going on though.
Right, still no closer.
Is it simply enough to download the MiKTeX Basic system and TeXniccenter?
So, you installed the basic MiKTeX package?
If so, then you should have the minimal setup to start composing LaTeX in any text editor.
Once you have composed your first LaTeX file, then you should be able to
run in a command window [assuming the path is setup correctly] (in the directory where you saved your file) "latex myfile". If that works, then your setup is working. (You should at least see if this works.)
For something fancier, you might have to setup your favorite text editor or something more like TeXniccenter.
When you enter in the full path, are you enclosing it in double quotes, e.g. "C:\Program Files\MiKTeX 2.5\miktex\bin"? If that doesn't work, you may want to experiment with including a backslash (' \ ') at the end of the path. A final possibility is to enter the path as something like c:\progra~1\miktex~1\miktex\bin
I have installed Basic MiKTeX (to the directory c:\texmf).
Then when I open TeXniccenter it asks me to "enter the full path of the directory, where the executables(latex, tex, etc.) of your TeX distribution are located".
So when I put in c:\texmf, since I thought MiKTeX was my distribution (and it is located at c:\texmf), I get an error message saying "The application "LaTeX" has not been found in the directory of your TeX-distribution. Please enter the directory where the executable files (tex.exe, latex.exe, etc.) are located, as your distribution's directory".
Try: C:\texmf\miktex\bin
or look in the texmf folder if there is a miktex folder and in the miktex folder click on the bin folder.
AT LAST! Thank you everyone for your advice!
Oh I am sorry, I didn't see that the problem had been solved on the 2nd page.
Related to Troubleshooting LaTeX Installation on Laptop
1. What is LaTeX and why should I use it on my laptop computer?
LaTeX is a typesetting software that is commonly used in scientific and technical fields to create high-quality documents with complex equations, diagrams, and tables. It is popular among researchers, academics, and professionals due to its ability to produce professional-looking documents with minimal effort.
2. Is LaTeX compatible with all laptop computers?
Yes, LaTeX is compatible with all laptop computers regardless of the operating system. It is a cross-platform software that can be used on Windows, Mac, and Linux laptops.
3. Do I need to have coding experience to use LaTeX on my laptop computer?
No, you do not need to have coding experience to use LaTeX. While it does use coding syntax, it also has user-friendly interfaces and templates that make it accessible to users of all levels.
4. Can I collaborate with others on a LaTeX document on my laptop computer?
Yes, LaTeX supports collaboration on documents through version control systems like Git. This allows multiple users to work on the same document simultaneously and track changes made by each user.
5. Are there any drawbacks of using LaTeX on my laptop computer?
One potential drawback of using LaTeX is the learning curve for beginners. It may take some time to become familiar with the software and its syntax. Additionally, if you are used to using other word processing software, the interface and functionality may be different and take some adjustment.
  • MATLAB, Maple, Mathematica, LaTeX
  • Computing and Technology
