Troubleshooting Mesh Issues in Gambit and Fluent CFD Tutorials
  • Thread starter Thread starter himanshu121
    Cfd Fluent
The discussion revolves around troubleshooting mesh issues in Gambit and Fluent, focusing on the characteristics of good and bad meshes, as well as specific challenges faced by users in creating and analyzing meshes for computational fluid dynamics (CFD) applications. The scope includes technical explanations, user experiences, and requests for assistance with specific projects.
  • Homework-related
  • Experimental/applied
  • Some participants suggest that the distinction between good and bad meshes is subjective and depends on the specific computational goals, emphasizing the importance of understanding the physical phenomena involved.
  • One participant mentions that a good mesh should not influence the solution, while others highlight the significance of aspect ratio and skew angle in mesh quality.
  • Concerns are raised about the stability of 3D finite element methods (FEM) and the need for appropriate grid density, especially in regions with large gradients.
  • Several users express difficulties with volume meshing in Gambit, reporting errors and seeking advice on alternative meshing techniques.
  • There are discussions about the limitations of certain CFD codes for specific applications, particularly in resolving acoustic waves in aeroacoustic analyses.
  • Participants share links to resources and manuals for further learning about Gambit and Fluent, as well as external CFD forums for additional support.
  • Some users inquire about specific projects, such as 3D meshing of wind turbine propellers and nozzle construction, seeking collaboration and advice from others.
  • One participant raises a question about importing vertices from MATLAB, indicating a need for integration between software tools.
  • Another user encounters an error when trying to open a mesh file in Fluent, prompting requests for troubleshooting assistance.
Participants express a range of views on what constitutes a good mesh, with no consensus on specific criteria. There are multiple competing perspectives on the effectiveness of different meshing strategies and the reliability of various CFD codes for specific applications.
Limitations include unresolved questions about specific mesh errors, dependencies on software versions, and the need for further clarification on certain technical terms and concepts related to meshing.
This discussion may be useful for students and professionals working with CFD software, particularly those using Gambit and Fluent for mesh generation and analysis in various engineering applications.
himanshu121
Hi
i want to know the difference b/w a good mesh and a bad mesh in gambit, pls give me suggestions and if possible a good link which gives a lot of tutorial on gambit and fluent,
I am attaching a msh file which i created using gambit can anyone pls suggest what is wrong with the above mesh
All the help is appreciated and thanks in adv.
Regards
Himanshu
i donn know how to upload such a large file of .msh format
u can find the the document here
http://home.iitk.ac.in/~himan/
There are no good meshes and bad meshes. The only thing a mesh must fulfill is the well posed algebraic transformation: it's jacobian must be well defined (no physical point should be described by two computational points at the same location).
What makes a mesh a good mesh is the kind of computation you want to calculate. Before working with fluent o gambit, you should have in your mind how your physical realisation is going to result, where are going to be the largest gradients and what are the critical localizations where the propagation of numerical errors is more likely to occur. A lot of manuals are on line (there are manuals attached to the cd of each program). Or go to the library and check out the Fluent manual.
In general, 3D FEM has particlar stability criterion regardless of software.
Here is a nice summary for CFD from Flow Science (Flow 3D)
http://www.flow3d.com/Cfd-101/criteria.htm
More generally -
http://www.flow3d.com/Cfd-101/cfd101.htm
GAMBIT: Geometry and Mesh Generation
GAMBIT is Fluent’s geometry and mesh generation software. GAMBIT's single interface for geometry creation and meshing brings together most of Fluent's preprocessing technologies in one environment. Advanced tools for journaling let you edit and conveniently replay model building sessions for parametric studies. GAMBIT's combination of CAD interoperability, geometry cleanup, decomposition and meshing tools results in one of the easiest, fastest and most straightforward preprocessing paths from CAD to quality CFD meshes.
http://www.fluent.com/software/gambit/index.htm
http://www.fluent.com/software/fluent/index.htm
http://www.fluent.com/software/fluent/grids.htm
http://www.fluent.com/software/fluent/dynamic.htm
Certainly mesh generation is important. I am not particularly familiar with GAMBIT, but I expect there is a default node/element density.
In certainly problems, the meshing would need adjustment, particular where there are large thermal gradients, otherwise the elements require appropriate shape/form functions. Computational efficiency is another issue that must be considered.
One can register for FLUENT support as a professional or academic/student -
http://www.fluent.com/support/fuscreg.htm
One may also try the following CFD forum -
http://www.cfd-online.com/Forum/
cfd
hi
i wanted to do a 3D meshing of a wind turbine propeller in gambit.then i wanted to do aero acoustic analysis on it .could anyone help me out. thanks
saadsami said:
hi
HI,I am going to to do a similar project too. Thus I am very pleased to keep in touch with you if possible. Please do not hesitate to contact me.Thank you very much.
My email:gmwsy@sjp.buaa.edu.cn
I don't mean to crap on your day, but I wouldn't trust those type of codes very much for aeroacoustics. We use CFX, and they claim at best 2nd order, and I've heard that the actual code runs at first order. This in layman's terms means that as you add more grid points, the solution doesn't converge quickly towards the actual solution (which as we know we will never get).
If you really want to resolve the acoustic waves, which can be magnitudes of orders down from the mean flow, you're going to need a LOT of grid. Also make sure you do whatever you can get to double precision for your solver, otherwise don't waste your time.
As with any third-party CFD solver, you'll get an answer, and it will probably seem right, but you have no idea what its really doing.
[/biased] :)
A good grid is a grid that has no influence on the solution. When a grid is too fine you could get numerical round of errors and when to course one could get truncation errors.
Typically you want to watch aspect ration and skew angle, both can be checked in Gambit.
Also, the grid type should really depend on your problem. hexahedral grids are typically preferred in combustion modeling.
The only time I've heard of there being a problem using too fine a mesh is if one is using a DRP scheme and just happens to start and end at the right point. Unless the grid size is approaching machine zero, IMHO you cannot ever make the mesh too small (making sure of course each line is at least d2 differentiable (assuming structured grid).
Like they said before, when you apply small changes to a GOOD mesh, there will be little difference in the solution. The opposite for bad meshes.
I like to make a uniform mesh and use the grid adaptation tools in fluent to refine the mesh for me. Otherwise, you will be spending A LOT of time building grids.
Hi , gmwsy@sjp.buaa.edu.cn I m student of beihang university. at the same time, i m studying gambit and fluent, too. i would like to know how to construct 3d nozzle in gambit. if you have experience with gambit please guide me how to construct that nozzle. my email is tunzawcn@gmail.com.
Hi all,
I am working on my project using gambit for geometry and mesh generation,
in edge meshing I have no problem and in face meshing by tri-pave element I can mesh my faces successfuly but for volume meshing I can not mesh my volume,I don't know why but for every selections of my elements gambit provides an error.
only steirstep meshing is compatible and successfull.But this type of meshing creates additional faces and volumes that provides errors for boundary conditions and fluent mesh checking.is there any way to mesh my project successfully with other types of meshing?
please help me if you can.
with regards,
arman.
arman2h_civil@yahoo.com
hi guys...am doing a project on turbine blades too...but there is a small problem in my mesh creation...there are no errors generated but my final pressure contour is not right... I am doing a 3d model by using a hex/tri mesh.
You probably should have started a new thread, but why do you think that the problem lies in the mesh?
because the only warning i get is during the mesh export...!
Warning for poorly shaped elements? How poor? Where in the grid? What's the solution look like there? There are MANY questions you need to figure out before you can try debugging a problem like this and truly identifying where the problem lies.
Maybe you're just running to large CFL.
I created a airfoil volume and placed it inside a cube. Gave the flow from left to right, subtracted the airfoil volume from the cube. Then I went for a volume mesh... Highly skewed elements <0.97...
There are about a billion things that can go wrong with a CFD run. If the only you have to look at is the grid, then you need to hit the textbooks.
hello
i'm asking is it possible to import vertexe from MATLAB program?
I want 2 know "how 2 define the successive ratio in meshin?"
about bryaton cycle
Hello everyone. I've made a mesh file in Gambit 2.4.6 and want to open it in FLUENT 6.3.26. But FLUENT can't read the mesh file. Can anyone help and say what to do. It gives me the following:
Error: bad syntax. Usage:
utility fe2ram dimension read_format zoning write_format [inputfile [outputfile]]
dimension: [-d2 | -d3 | -surface]
Building...
grid,
Error: Null Domain Pointer
Error Object: ()
how to down load cfd
15K
56K
10K
20K
