Trying to understand power/work
  • Thread starter Thread starter southernson
The discussion centers on the relationship between power, work, and acceleration in vehicles, particularly tractors and cars. It highlights that while a tractor with double the power can pull the same load at twice the speed, the acceleration of a vehicle is more complex due to the kinetic energy equation, which involves the square of velocity. It is noted that to double the rate of acceleration for a constant mass, four times the power is required, not just double. The confusion arises when considering whether a car with double the power can accelerate from 0 to 60 m/s in half the time, as this would necessitate greater force. Overall, the conversation emphasizes the intricacies of power dynamics in horizontal motion compared to vertical lifting.
southernson
you see a lot of reference to the fact that a forklift or winch or something with "twice" the power of a another one can lift twice the mass in the same time, or the same mass in half the time, etc. This makes sense.
Power in the horizontal direction makes less sense to me. If a tractor has twice the power it can similarly do twice the work in the same time, but can it pull the same mass from point A to B in half the time? If you look at power as KEf-KEi/t, it would appear that it can't because velocity is squared in the KE equation (KE = 1/2mv^2).
Can someone help me clarify this?
Well, tractors don't pull at the same power regardless of speed. But if they they did then I guess the velocity of the tractor would increase quadratically (assuming no friction).
Tractors are normally pulling against a constant load, not acceleration. Power equals force times speed, so a tractor with double the power will be able to pull the same load (tension force) at twice the speed.
In the case of acceleration with a constant mass, since the change in energy is relative to 1/2 m V^2, then twice the power only increases the rate of acceleration by SQRT(2) (with the same mass), and it takes 4 times the power to double the rate of acceleration (or think of 4 times the power as twice as much force at twice as much speed with constant acceleration).
Sorry guys, I'm still confused. Let's use a different example. Say just a car with an engine of power P and another with a power of 2P. If the first can go 0 to 60m/s in 20 seconds can the second to it in 10 seconds? If so, this can only happen by the second engine causing a faster acceleartion. How is that going to happen without a greater force?
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
