How Can Turbulence Dissipation Rate Be Independent of Viscosity?
The discussion centers on the concept of turbulence dissipation rate, specifically the relationship between the rate of kinetic energy dissipation (ϵ) and viscosity in turbulent flows. It highlights the equation ϵ ~ u³/l, indicating that the dissipation rate is independent of viscosity at large scales, while at smaller scales, ϵ is calculated using viscosity through the equation ϵ = 2*v*Sij*Sij. The confusion arises from the inconsistent terminology used in literature regarding "dissipation" and "dissipation rate," leading to a misunderstanding of how viscosity influences these calculations at different scales.
  • Understanding of turbulent flow dynamics
  • Familiarity with Richardson's energy cascade theory
  • Knowledge of the Kolmogorov scale in turbulence
  • Basic grasp of fluid mechanics equations, particularly related to energy dissipation
  • Research the implications of the Kolmogorov scale on turbulence and energy dissipation
  • Study the differences between large-scale and small-scale turbulence dynamics
  • Examine the role of viscosity in turbulent flows and its effects on energy dissipation
  • Explore advanced texts on turbulence modeling and the energy cascade process
Researchers, fluid dynamics engineers, and students studying turbulence and energy dissipation in fluid mechanics will benefit from this discussion.
K41
I've been reading about dissipation of energy in turbulent flows. I've read in various places about Richardson's idea of Energy cascade. But one of the biggest problems I have is understanding how the books (or texts online) all refer to ϵ, the rate of dissipation of kinetic energy, being independent of viscosity, that is:
ϵ ~ u³/l .........EQ1
where u and l denote the characteristic length and velocity scales of the large eddies.My problem is as follows. The texts ALL say that the energy dissipation RATE is independent of viscosity. Okay. But then the majority of books then say, at the small scales:
ϵ = 2*v*Sij*Sij .............EQ2
So how can ϵ, the rate of dissipation of kinetic energy, be independent of viscosity, if at the small scales it can be calculated from viscosity?
The book I'm reading also says sometimes that EQ 2 is simply "dissipation" rather than "dissipation rate" or that other times ϵ represents "dissipation of turbulent energy". It seems to regularly use different terminology for the same equation and same symbol. So I need some clarity here.
Any help?
EDIT:
Some text alluded to the fact that the dissipation stage is last process in the entire energy cascade of processes and therefore the dissipation rate must be calculated from the first process in the cascade processes, hence ϵ ~ u³/l but I didn't understand this because, although I agree that the rate of dissipation may depend on how quickly energy cascades to the smaller scale, it must surely also depend on how quickly the energy is transformed to heat at the smallest Kolmogorov scale? I understand that the inertial forces dominate over viscous forces for large eddies, but I don't see how viscosity can be neglected from a rate calculation once you get down to the small scales.
Compare the magnitudes of the "dissipation" rates.
  • · Replies 0 ·
  • · Replies 17 ·
