Turkish Tubitak olympiads problems and solutions by Rafiq Abbasov
- Thread starter Killua Rafiq
- Start date
The discussion revolves around advanced physics problems related to the Turkish Tubitak Olympiads, with a focus on specific problem statements and their solutions. Participants are sharing their insights and corrections regarding the solutions presented in a PDF document.
- Mixed
- Participants are attempting to clarify and correct solutions to specific problems, particularly focusing on the relationships between variables in physics equations. There are discussions about the accuracy of equations and the implications of assumptions made in the problem statements.
The discussion is ongoing, with multiple participants providing corrections and suggestions for improvement. Some participants express confusion over specific equations, while others offer insights into the physics concepts involved. There is a mix of agreement and disagreement on the interpretations of the problems.
Participants are addressing potential errors in the original solutions, particularly regarding the understanding of adiabatic and isothermal processes. There are mentions of the need for clarity in the definitions and assumptions used in the problems.
- 15,937
- 9,120
- 18
- 2
Killua Rafiq said:Homework Statement:: Hi guys,i want to share with you my project about advanced physics-Physics olimpiads.I find 5 hard problems and solved these.I think it will be useful for students who prepares to olimpiad's and interests in adv physics.Have fun.
Relevant Equations:: $P=\rho gl$,$GM=gR^2$(and etc.)
Pdf is below.
- 18
- 2
kuruman said:Your solution to Problem 1 is incorrect. It should be $$\frac{l_1}{l_2}=\frac{\tan\theta-\mu_2}{\tan\theta-\mu_1}.$$
No.It was test and there wasn't variant you said.I explained this problem.There $\mu_2 > \mu_1$.Try to solve againkuruman said:Your solution to Problem 1 is incorrect. It should be $$\frac{l_1}{l_2}=\frac{\tan\theta-\mu_2}{\tan\theta-\mu_1}.$$
- 18
- 2
- 15,937
- 9,120
Also, please familiarize how to use LaTeX here. You need two $ instead of one. Also you can use ## for inline equations.
- 18
- 2
I wrote same,bruhkuruman said:I messed up an overall negative sign and the correct solution should be $$\frac{l_1}{l_2}=\frac{\mu_2-\tan\theta}{\tan\theta-\mu_1}.$$You have $$\frac{l_1}{l_2}=\frac{\mu_2\tan\theta}{\tan\theta-\mu_1}.$$Did you omit the sign between ##\mu_2## and ##\tan\theta##?
- 18
- 2
The answer should be $$\frac{\mu_2 tan\theta}{tan\theta -\mu_1}$$Killua Rafiq said:I wrote same,bruh
- 18
- 2
- 18
- 2
- 18
- 2
@etotheipin @kruman i am so sorry.I forgot just add "-".Killua Rafiq said:I wrote same,bruh
- 15,937
- 9,120
It's OK. We all make mistakes.Killua Rafiq said:@etotheipin @kruman i am so sorry.I forgot just add "-".
- 18
- 2
Edit:The answer must be in first problem :$$\frac{\mu_2-tan\theta}{tan\theta-\mu_1}$$Killua Rafiq said:Homework Statement:: Hi guys,i want to share with you my project about advanced physics-Physics olimpiads.I find 5 hard problems and solved these.I think it will be useful for students who prepares to olimpiad's and interests in adv physics.Have fun.
Pdf is below.
- 15,937
- 9,120
- 18
- 2
kuruman said:It's OK. We all make mistakes.
But in ishoterm "T" is const.I wanted to specify that ishotermal and aidabatic similar except adiabatic prosses gives eneregy only with work.And i am agree with you.I will fix problemskuruman said:While I have your attention, check your solution to Problem 5. The process A-B is adiabatic. Near the end of your solution you say that it is a isotherm. That is simply not true. I suggest that you correct this and post a corrected version of the pdf.
- 15,937
- 9,120
- 18
- 2
Agreed Totally.Check it https://www.physicsforums.com/threads/turkish-tubitak-olympiads-problems-with-solutions-by-rafiq-abbasov-fi.992496/kuruman said:The isothermal and the adiabatic processes are quite different and I would not call them similar. In an isothermal process the temperature does not change and the work done by the gas is equal to the heat that enters the gas. In an adiabatic process, no heat enters the gas and the temperature drops or increases depending on whether the gas is doing positive or negative work. The Carnot cycle is an example of the use of two isotherms and two adiabats to get the highest possible efficiency.
- 15,937
- 9,120
All bugs are not fixed. In the solution to Problem 5 (this version), you claim that in an adiabatic process the temperature does not change. That is not true. It could be true for a solid that does not change its volume when heat is added to it. A gas can expand (or contract) and do positive (or negative) work on the environment. As you know, according to the first law ##\Delta U=Q-W##, where ##W## is the work done by the gas, ##Q## is the heat that enters the gas and ##\Delta U## is the change in internal energy of the gas. In an adiabatic process, ##Q=0## so that ##\Delta U=-W##. This says that if the gas expands adiabatically and does positive work as is the case in Problem 5, the internal energy and hence the temperature must decrease.Killua Rafiq said:Homework Statement:: Again me.All bugs fixed
Relevant Equations:: &&P=\rho gl$$
$$E=mc^2$$
Basic stuff like this must be clear in your mind before you attempt Olympiad-level problems.
- 18
- 2
There is no reason to be rude like this.Dude,i remember i wrote T=constant in previous document?. There was ishoterm because of i confused and i was exhausted.So i forgot change this.I know kinda most part adv physics but it was my first article.I will fix this.kuruman said:All bugs are not fixed. In the solution to Problem 5 (this version), you claim that in an adiabatic process the temperature does not change. That is not true. It could be true for a solid that does not change its volume when heat is added to it. A gas can expand (or contract) and do positive (or negative) work on the environment. As you know, according to the first law ##\Delta U=Q-W##, where ##W## is the work done by the gas, ##Q## is the heat that enters the gas and ##\Delta U## is the change in internal energy of the gas. In an adiabatic process, ##Q=0## so that ##\Delta U=-W##. This says that if the gas expands adiabatically and does positive work as is the case in Problem 5, the internal energy and hence the temperature must decrease.
- 18
- 2
Killua Rafiq said:There is no reason to be rude like this.Dude,remember i wrote T=constant in previous document?. There was ishoterm because of i confused and i was exhausted.So i forgot change this.I know kinda most part adv physics but it was my first article.I will fix this.
- 15,937
- 9,120
- 20,819
- 28,461
It also has derailed into its meta level, which is why I deleted this off topic part of the discussion.
This thread is closed.
- · Replies 2 ·
- Replies
- 2
- Views
- 2K
- Replies
- 0
- Views
- 2K
- · Replies 5 ·
- Replies
- 5
- Views
- 2K
- · Replies 8 ·
- Replies
- 8
- Views
- 3K
- · Replies 4 ·
- Replies
- 4
- Views
- 2K
- · Replies 1 ·
- Replies
- 1
- Views
- 4K
- · Replies 37 ·
- Replies
- 37
- Views
- 5K
- Replies
- 4
- Views
- 4K
- · Replies 3 ·
- Replies
- 3
- Views
- 3K
- Replies
- 2
- Views
- 2K
