How to Calculate Acceleration in a System with Two Blocks and a Pulley
The discussion focuses on calculating the acceleration of a system involving two blocks and a pulley. The system includes a block of mass m1 = 1 kg on a table with a coefficient of friction µ = 0.77, a pulley with mass m2 = 0.7 kg and radius 15 cm, and a falling block of mass m3 = 3 kg. The correct approach involves applying Newton's second law and the rotational dynamics of the pulley, specifically using the equation for torque as (T3 - T1)R. This adjustment leads to the correct calculation of acceleration.
  • Understanding of Newton's second law of motion
  • Familiarity with rotational dynamics and torque
  • Knowledge of frictional forces and their calculations
  • Basic algebra for solving equations
  • Study the principles of rotational motion and torque calculations
  • Learn about frictional force calculations in different scenarios
  • Explore advanced applications of Newton's laws in multi-body systems
  • Practice problems involving pulleys and inclined planes for deeper understanding
Students in physics, engineers working on mechanical systems, and anyone interested in dynamics and kinematics involving pulleys and friction.
huskydc
A block of mass m1 = 1 kg rests on a table with which it has a coefficient of friction µ = 0.77. A string attached to the block passes over a pulley to a block of mass m3 = 3 kg. The pulley is a uniform disk of mass m2 = 0.7 kg and radius 15 cm. As the mass m3 falls, the string does not slip on the pulley.
With what acceleration does the mass m3 fall?
i did the following:
[A]sum of Force on mass 1: T(1) - f = m(1) a
thus, T(1) = m(1)a + mu*m(1)g
sum of torque on mass 2: RT(3) = I *alpha
[C]sum of forces on mass 3: m(3)a = m(3)g - T(3)
thus, T(3) = m(3)g - m(3)a
and since alpha = a/R and I = .5 m(2) R^2
I plug in equatiion for T(3) into , and got something like this:
R m(3) g
------------------- =a
.5 m(2) R + R m(3)
and plug in numbers, didn't work out...any hints?
The problem is in .
The torque on m2 results from the difference in tensions in the rope on either side of the pulley.
That torque should be (T3 - T1)R
i got it, thanks!
  • · Replies 23 ·
  • · Replies 22 ·
