Two football players are running at each other
  • Thread starter Thread starter physstudent1
    Running
When two football players with equal momentum collide, the player who lowers their center of gravity typically gains an advantage. A lower center of gravity reduces their rotational moment, making it harder for them to be knocked down. The concept of pivoting around the feet is crucial, as it influences stability during the impact. Additionally, the goal is to disrupt the opponent's movement, focusing on their legs and feet. Overall, maintaining a lower center of gravity enhances balance and resilience during physical confrontations.
physstudent1
This may be a simple question but say if two football players are running at each other with equal momentum why does the one who gets lower so to speak win?
Because of their centers of gravity.
If you're running, and you trip on a rock, you're going down. But if you're running and a floating rock at rest hits you in the chest. You're not going to fall down are you?
Another aspect to consider in your scenario is that the ideal goal is to negatively influence the opponents "method of locomotion"
In this case, it is his legs and feet.
very simple. Your feet are the pivoting point.
rotational moment (that is the tendency for your body to rotate forward or backwards) is given by :
moment= force x perpendicular distance of line of force to pivot
where the force in this case is your own weight.
given this, if your centre of gravity is lower, and considering all else equal, your rotational moment is lower because the perpendicular distance of line of force to pivot is also lower ,so according to the equation above, it is harder to make you fall.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
