Two Particles Collide - Momentum and Energy
The discussion centers on a physics problem involving the collision of two particles with masses of 3.000u and 4.000u, moving at velocities of 0.8c and 0.6c, respectively. The post-collision scenario includes a 6.000u mass at rest, prompting the need to determine the mass and speed of the other object and the change in kinetic energy. Participants emphasize the importance of applying conservation of momentum and energy equations, specifically γ1m1v1 + γ2m2v2 = γ3m3v3 + γ4m4 and γ1m1c2 + γ2m2c2 = γ3m3c2 + m4c2, while also noting the challenges posed by the rest mass. The final calculations yield a speed of 0.25c for the unknown mass, which is determined to be approximately 3.873u.
  • Understanding of relativistic momentum and energy equations
  • Familiarity with the concept of gamma (γ) in relativistic physics
  • Knowledge of conservation laws in physics, specifically momentum and energy
  • Ability to manipulate algebraic equations involving variables and constants
  • Study the derivation and application of the Lorentz factor (γ) in relativistic mechanics
  • Learn how to solve conservation of momentum problems in relativistic contexts
  • Explore kinetic energy calculations in relativistic collisions
  • Investigate the implications of mass-energy equivalence in particle physics
Students and educators in physics, particularly those focusing on relativistic mechanics, collision theory, and energy conservation principles. This discussion is also beneficial for anyone preparing for advanced physics examinations or tackling complex physics problems.
TristanJones
Q: A 3.000u object moving to the right through a laboratory at 0.8c collides with a 4.000u object to the left of the laboratory at 0.6c. Afterward, there are two objects, one of which is a 6.000u mass at rest.
A) what are the mass and speed of the other object?
B) determine the change in kinetic energy in the collision
γ1m1v1 + γ2m2v2 = γ3m3v3+γ4m4v4
γ1m1c2+γ2m2c2 = γ3m3c2+m4c2
3.= The attempt at a solution
I've been struggling with this for a while, and haven't really made much headway. The part I'm finding difficulty with is using both conservation of momentum and conservation of energy formulas when I need to consider that the third particle technically isn't moving. I don't necessarily want the answers handed to me - just a few tips to get me headed in that direction would be much appreciated.
Try working with momenta and energies instead of velocities.
do you mean eliminating the v as a variable? i used the conservation of energy and momentum formulas, but there's just something not quite working. i end up with more unknowns than i know what to do with
Aren't the unknowns in your equations the gamma3 and the m3 (for 2 equations this is solvable)?
and whatever V3 would be in the momentum equation (unless I'm not supposed to use the momentum equation)
The v3 and gamma3 are the "same" unknown... aren't they?
gahhh, you're right. i think my issue was dealing with the one particle which was at rest (and has no momentum). i'll play around with it a bit
Try using ##E^2 = p^2c^2 + m^2c^4##
These problems never work out if you try to solve for ##v## and ##\gamma##!
PeroK said:
These problems never work out if you try to solve for vvv and γγ\gamma!
Well they do, it's just a very rough way to do things... Either way you have to apply the conservation of energy/momentum at some point (in one way or another).
But the expression for the momentum conservation is not quiet right...(except for if vi are vectors)
If Particle 4 is the one at rest after the collision we have
\begin{array}{rcrcrc}<br /> \gamma_1 m_1 v_1 &amp;+&amp; \gamma_2 m_2 v_2 &amp;=&amp; \gamma_3 m_3 v_3 &amp;+ &amp;0 \\<br /> \gamma_1 m_1 &amp;+&amp; \gamma_2 m_2 &amp;=&amp; \gamma_3 m_3 &amp;+&amp; m_4<br /> \end{array}<br />
In the second equation we dropped the common factor ##c^2## from all terms on both sides.
From the known quantities, the equations allow us to find ##\gamma_3 m_3## and ##\gamma_3 m_3 v_3##; so we can get ##v_3## by taking a ratio of known quantities. Once we know ##v_3## we are almost done.
@Ray Vickson - ok, so for the momentum I got
γ3m3v3= 1uC
for energy I got: γ3m3= 4u
so I divide the first one by the second to get v3= 0.25c (?)
ok, then I used that, calculated gamma, and inserted back into the momentum equation to solve for m3 and got 3.873 u. should be good to go. thanks!
seems legit...
unless you got something entirely different and I am to to lunch, hehe
Yes I got something totally different because I omitted the m4, as if it was not there...
As for the questionmark for the v3, it's true that \frac{p}{E}= v for massive particles, and it's also the same for massless particles too...
there are no massless particles in this equation though ... sorry, I'm just not entirely sure if you're agreeing with my end result, or implying I should make changes
nah, I just made a general statement for your questionmarked phrase "so I divide the first one by the second to get v3= 0.25c (?)"
That p/E happens to be always equal to the velocity.
it seems I agree...
welp, cheers!
  • · Replies 54 ·
11K
