Two physics KE/PE questions(and possibly more, studying for a test)
axforts
a carpenter moves his .5 kg hammer at 3m/s when it contacts a nail. The nail receives an average force of 75N as it is driven 2cm int the wood board. The carpenter notices that the nail feels warm after he hits it with the hammer. How much heat energy was transferred to the nail.
W = fd
work w =force Fx distsnce D
w=75nx.02m
w=1.5j
Maybe I am supposed to do Ke = .5mv^2 and get 2.25J, then 2.25- 1.5J = .75J?
Except that was wrong?
Next problem
How much work is done by accelerating a 1200kg card from rest to a speed of 12m/s while it is movin up a frictionless hill that is 18m high.
force = mass x acceleration F= 1200x12=14400n
w=force x distance w=14400x18=259200j
=259.2kj
Except my friend is getting 298080J. Not sure whos right here. Thanks everyone!
Hes doing
W = mg(18) + .5m(12)^2
When you calculate the work, you do need to take into account any change in potential energy. Try that for the first problem and see if it gets you a better result.
So for the first one, I tried
5mv^2 + mgh = W + Q
W = fd = 75N * .02m
= 1.5J
.5(.5kg)(3m/s)^2 = 2.25J
= KE
.5kg * 9.8m/s^2 * .02m = PE = .98J
2.25+ .98 = 1.5 + Q
So is Q 1.73J?
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
