Two resistors and total resistance
The problem involves two resistors, R1 and R2, with given equivalent resistances of 710 ohms in series and 200 ohms in parallel. Participants are tasked with determining the values of R1 and R2, as well as the current through the resistors when connected to a 12V battery.
  • Participants discuss the definitions of equivalent resistance and question the interpretation of the problem statement. Some express confusion about the total resistance values and how they relate to the individual resistors. Others attempt to clarify the equations for series and parallel connections and explore the implications of having two equations for two unknowns.
The discussion is ongoing, with participants sharing their interpretations and attempting to clarify the problem's wording. Some have suggested writing out the equations based on the given resistances, while others are exploring their understanding of the relationships between the resistors.
Participants note the challenge of solving for two unknowns given the total resistances without additional information or visual aids. There is an emphasis on the need for clarity regarding the definitions and relationships involved in the problem.
bkl4life
Two resistors, R1 and R2, have an equivalent resistance of 710 ohms when they are connected in series and an equivalent resistance of 200 ohms when they are connected in parallel.
a) what are R1 and R2
b) Determine the current traveling through the resistors when they are connected in series and parallel to a 12 v battery.
V=IR
R1 and R2 are different.
In a series the equation is just: R1+R2+R3 and for a parallel it is 1/R1+ 1/R2
R1 and R2 must add up to get 910 (total).
I'm just not sure how.
I am a little confused by the wording. What do you mean by "equivalent resistance"? Do you mean the total resistance or that they are equivalent (the same)? If it is the former, then why must they add up to 910 ohm? Don't they add up to 710 when connected in serial?
Equivalent resistance here means total... I think. The question seems easy and yet I can't do it.
I think the wording may be confusing you. This may help clear it up:
The total resistance when the 2 resistors are connected in series is 710 ohms.
The total resistance when the 2 resistors are connected in parallel is 200 ohms.
With this information, how many independent equations can you write? How many unknowns do you have?
Once you have solved for the resistances, you will be able to calculate the current(s) using Ohm's Law.
Parallel is 1 / [ (1/R1) + (1/R2) ]
"The reciprocal of the sum of the reciprocals."
Another form that you can use when there are exactly two resistors is R1 R2 / (R1 + R2)
"The product over the sum."
I have never done a problem like this. In class we are given the total resistance or a drawing. I'm not sure what to do when I am given the total resistance and have to find the two resistors.
For parallel: 150=1/r1+1/r2
Would I get the same answer for the two resistors.
To solve for 1/r1 I could plug 1 in for r2 and I end up getting::
R1=1/149= .00667
You have two unknown, R1 and R2, and you have two equations, one for the connection in series and one for the connection in parallel. With two unknowns and two equations, you can simply set up your system of equations and solve for R1 and R2.
Can you write the two equations?
  • · Replies 19 ·
  • · Replies 23 ·
