Understanding q: Why does dqsurr = -dqsys?
The equation dq_{surr} = -dq_{sys} represents the conservation of energy principle in thermodynamics, specifically illustrating that the heat lost by a system is equal to the heat gained by its surroundings. This relationship is derived from the first law of thermodynamics, which asserts that the total energy in an isolated system remains constant. The discussion emphasizes that this equality holds true in the absence of work being done on or by the system. Understanding this principle is crucial for grasping fundamental thermodynamic concepts.
  • Understanding of the first law of thermodynamics
  • Familiarity with the concepts of heat transfer
  • Basic knowledge of energy conservation principles
  • Mathematical skills for manipulating equations
  • Study the first law of thermodynamics in detail
  • Explore heat transfer mechanisms in thermodynamic systems
  • Learn about the implications of work in thermodynamic equations
  • Investigate real-world applications of energy conservation in engineering
Students of physics, engineers, and anyone interested in thermodynamics and energy conservation principles will benefit from this discussion.
santimirandarp
The question is:
why ##dq_{surr}=-dq_{sys}##?
q=heat, surr=surroundings, sys=system.
Is there any simple way to understand this?
Science news on Phys.org
santimirandarp said:
The question is:
why $dq_{surr}=-dq_{sys}$?
Conservation of energy?
How do you derive that expression from the conservation of energy?
If the heat (energy) leaves the system it must go to the surroundings; and, vice versa. The change in one must be equal and opposite to the change in the other.
I'm sorry but I don't understand that answer
Is your problem conceptual or mathematical?
Do you understand the concept of conservation? It means that the total amount of something stays the same over time.
Mathematically this means that if you add up all the changes in something it must come to zero. In this case:
Change in energy (system) + change in energy (surroundings) = 0
or:
##dq_{sys} + dq_{sur} = 0##
or:
I know maths and conservation.
But why do you say heat is conserved?
Because that's what you said in the original post. Your equation is equivalent to conservation of heat energy.
Say, for example, you have:
Change in the number of apples in the system = - change in the number of apples in the surroundings
And you asked "is there a simple way to explain this?" Then I'd say "conservation of apples".
Apples put in the barrel 1 = - apples put in barrel 2
It is not. The equality I showed is exactly what I don't understand ('why ...'). So I'm asking: where does the equality comes from? (and heat is not so simple as apples).
It's the first law of thermodynamics.
It is not. The first law implies that universe internal energy is conserved and also:
##\Delta U_{sys}=(W+Q)_{sys}=-\Delta U_{surr}=-(W+Q)_{surr} ##
so ##(W+Q)_{sys}=-(W+Q)_{surr} ##
I don't see how it follows that dq=-dq_{surr}
This is only true in the absence of any work.
I've found it quoted as a general truth. Thanks.
Are you telling us or asking us? That this is a universal truth? And, that the obvious explantion that it's the first law in the absence of work won't do?
I'll ask the second part on a different question.
You would have to quote the source. Either it is wrong, it is about a specific situation or you have misunderstood it.
Anything that’s a "general truth" will be stated in many places.
