Typical values and danger of circuit components
Understanding typical voltage, current, and resistance values is crucial for safely using a programmable DC source like the Yokogawa 7651. The device can output 32 volts at 120 mA, which is generally safe unless connected to large inductors or sensitive components. It's essential to be cautious with current levels, as exceeding a few milliamps can be dangerous, and proper biasing of components like electrolytic capacitors is necessary to prevent damage or explosions. Beginners are advised to start with low voltages and simple circuits to build confidence and understanding. Always ensure circuits are powered down before making adjustments to avoid accidents.
xianyang
Hi guys,
I am a physics graduate, currently working in an experimental lab. Before coming here, I have no solid experience in lab stuffs. Anyway I enjoy working at lab a lot.
The first task I have is to learn and master a programable DC source (Yokogawa 7651). To do this, I personaly think that I need some knowlegde for the following:
1) What are the typical values of voltage, current, resistance of a circuit? I would like to know the typical values of them ranging from as small as table circuits to industrial circuits.
2) How dangerous is a value of voltage, or current? I think we can calculate the power consumed by the whole circuit by a simple estimate P=VI=V2/R=I2R. However, this is for the whole circuit, rather than for a small object such as our body when coming into contact with the circuit. Make it precise, is there anyway to calculate the power that our body will be receiving from a circuit, given some necessary information?
I would appreciate if you guys like to share with me you says or some links that answer to the above doubts.
Thanks,:smile::confused:
Xian Yang
Looks like a nice power supply although the front panel is confusing. Maybe with the instruction book it may become clearer.
It can generate 32 volts at 120 mA. These are quite safe for you to touch unless you apply that voltage to a large inductor. In that case, you could get a large voltage generated.
Many electronic devices would not stand 32 volts and may be destroyed. So you would have to be aware of that.
Devices like electrolytic capacitors have voltage ratings that can be less than that and they also have polarity requirements.
LEDs and Zener diodes have to have a series resistor that must be appropriate for the device and the power source.
Otherwise, you should perhaps set up a few small projects to learn how to use it. Keep the voltage low for a while until you get used to it.
I guess it could be used for calibrating other measuring equipment like digital voltmeters, rather than actually powering equipment with it.
When I hook up the power supply to my circuit and turn it on, the first thing I look to see is how much current the circuit is drawing out of the power supply. I don't know what exactly you will be doing, but most circuits you throw together on a breadboard won't need more than several mA. Of course, check the data sheets and your circuit before you flip the switch so you have an idea of how much current there should be. If you see the current jump up to a couple hundred mA or over 1 A, something may be wrong. Current at this level is extremely dangerous.
Make sure that if you use electrolytic capacitors, you have them biased properly because they can get damaged, smoke, and even pop out at a high speed.
Make sure that if you use op amps you are properly biasing them because they too can easily be damaged.
As vk6kro said, you may want to keep voltage low to start with. But especially keep current low; once you get above a few mA you need to be careful.
FYI,
Capacitors do blow up violently when hooked up badly. They also release lots of smoke (white with purpleish tint in my case).
However, if you don't have your face over them when it blows up then you should be fine. If you do then stop breathing, turn off the PSU and go wash your face.
I'd recommend you build a few simple circuits, LED/resistors then put in switches and so on.
120 milliamps is not a lot, but it should drive a couple LEDs
The most dangerous component you could encounter is another power supply.
This one may be well prepared and protected from other power sources, but it might not.
If it encountered a higher voltage, you may well blow up some extremely expensive components or turn your power supply into a heap of scrap.
So, always ensure that any circuit you apply it to has the power disconnected by pulling the plug from the wall. Also, capacitors, especially electrolytic capacitors can hold a charge for a long time and need to be discharged before any testing.
Thanks guy!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
