What Are the Best Resources to Learn About UV Sanitization?
For understanding UV sanitization, several resources are recommended, including materials from bulb suppliers like GE, which provide valuable information on UV rays and their properties. The discussion emphasizes the need for practical knowledge rather than complex mathematical models, focusing on specifications for UV bulbs and their efficacy. Users suggest exploring manufacturer guidelines and product datasheets to gain insights into UV intensity and application. Additionally, industry publications and online courses may offer foundational knowledge about UV sanitization techniques. Overall, leveraging supplier resources and industry literature can effectively support product development in UV sanitization.
tihort
I am a new product development engineer and am working on figuring out a UV sanitization product.
Do you know of a good resource to understand UV rays, its properties, using UV, etc.?
I am not looking for detailed math models and analysis, but rather, a resource that will help me understand enough to spec out the kind of UV bulb needed, the intensity needed and to be able to understand/ predict its efficacy.
Thank you in advance.
Science news on Phys.org
Our tissue culture hoods all have UV germicidal bulbs in them- have a look at what the bulb supplier says (GE, most likely)
thank you very much! there is a lot of info available through GE.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
