Art said:
So you wish to retract this then?
humans have been emitting 6-7 gigatons a year
because even if we had been generating this level of CO2 for the past 150 years, which of course we haven't, it still only equals 130 ppmv with no reabsorbtion whatsoever.
We've been emitting about 7 Gt of Carbon equivalents, from an annual rate of nearly 30 Gt of CO2. Multiply your numbers by about 4 to get the total estimate: about 500ppmv. Now throw in reabsorption. All the numbers make sense; no need to retract anything.
Change in land use springs to mind as does volcanic activity, even a small upward deviation in volcanic activity in a few of the last 150 years would account for a huge chunk of CO2 given that it's normal annual output is ~60Gt.
According to the US Geological survey, volcanoes contribute only abou 0.2 Gt per year of CO2. That's 300 times smaller than your number, and tiny when compared to CO2 from fossil fuels.
Source:
US Geological Survey
Comparison of CO2 emissions from volcanoes vs. human activities.
Scientists have calculated that volcanoes emit between about 130-230 million tonnes (145-255 million tons) of CO2 into the atmosphere every year (Gerlach, 1999, 1991). This estimate includes both subaerial and submarine volcanoes, about in equal amounts. Emissions of CO2 by human activities, including fossil fuel burning, cement production, and gas flaring, amount to about 27 billion tonnes per year (30 billion tons) [ ( Marland, et al., 2006) - The reference gives the amount of released carbon (C), rather than CO2, through 2003.]. Human activities release more than 130 times the amount of CO2 emitted by volcanoes--the equivalent of more than 8,000 additional volcanoes like Kilauea (Kilauea emits about 3.3 million tonnes/year)! (Gerlach et. al., 2002)
Here you go. And note this is a peer reviewed report rather than the politically reviewed report the IPCC issue.
http://www.uoguelph.ca/~rmckitri/research/ispm.html
And for completeless, here's a rebuttal from Realclimate:
/www.realclimate.org/index.php/archives/2007/02/fraser-institute-fires-off-a-damp-squib/[/URL]
[quote]Why go to all the trouble of producing an "independent" summary? The authors illuminate us with this wisdom regarding the official Summary for Policymakers: "A further problem is that the Summary for Policy Makers attached to the IPCC Report is produced, not by the scientific writers and reviewers, but by a process of negotiation among unnamed bureaucratic delegates from sponsoring governments." This statement (charitably) shows that the Fraser Institute authors are profoundly ignorant of the IPCC process. In fact, the actual authors of the official SPM are virtually all scientists, and are publically acknowleged. Moreover, the lead authors of the individual chapters are represented in the writing process leading to the SPM, and their job is to defend the basic science in their chapters. As lead author Gerald Meehl remarked to one of us on his way to Paris: "Scientists have to be ok, they have the last check. If they think the science is not represented, then they can send it back to the breakout groups. " [/quote]
And since we now have Ross McKitrick (Co-ordinator of the ISPM paper) on our plates, it may be noteworthy to point to the following:
[quote]In previous rounds of the debate, Lambert has shown that McKitrick messed up an analysis of the number of weather stations, showed he knew almost nothing about climate, flunked basic thermodynamics, couldn’t handle missing values correctly and invented his own temperature scale.
But Tim’s latest discovery really takes the cake. It’s well-known that the rate of warming varies with latitude, but McKitrick and Michaels find no such effect for their variable, which is the cosine of absolute latitude. Lambert checked and, amazingly enough, found that the data set used by McKitrick and Michaels had latitude in degrees, but the cosine function in the SHAZAM econometric package, they used expected input in radians (which is what any mathematically literate person would expect). If you apply this function to angles measured in degrees you get nonsense.
Once Lambert did the correct analysis, latitude was highly significant and the economic variables became much less important. The results reported by McKitrick and Michaels can be explained by an obvious confounding effect. Rich countries tend to be at high latitudes, and so GDP acts as a proxy for latitude.[/quote]
Sources:
http://timlambert.org/2004/08/mckitrick6/
[url]http://crookedtimber.org/2004/08/25/mckitrick-mucks-it-up[/url]
Regarding McKitrick's rebuttal of Mann's paper and the subsequent corrections published by McKitrick and Mann:
[quote] Mann, Bradley and Hughes have published some corrections to the supplementary information for the famous hockey stick graph showing the temperature record of the last 1000 years. They say that the errors do not affect their published results. This could explain why McKitrick and McIntyre could not reproduce their results, but McKitrick is continuing to insist that Mann’s graph is wrong.
McKitrick has also published some errata. Unlike Mann’s error McKitrick’s error affects his results:
[b]Figure 3 in the Cooler Heads Briefing on TBS contains an error. Tim Lambert of Australia has pointed out that missing data were handled differently between Figures 2 and 3, and when this is fixed the example no longer illustrates the intended point. The point (that the trend can change if the averaging rule is changed) is shown in this Revised Spreadsheet. Our thanks to Tim Lambert for pointing out the error. [/b] [/quote]
Sources:
http://timlambert.org/2004/05/mckitrick3/
[URL]http://timlambert.org/2004/07#mckitrick5[/URL]
PS: Some of this is covered in Sky's post above, which I hadn't seen before I was writing this.
