Uncover Traps in Spacetime Diagrams: Bob & Alice's Cases
  • Context: Undergrad
  • Thread starter Thread starter Freixas
    Diagrams Spacetime
The discussion revolves around the potential pitfalls and misunderstandings associated with spacetime diagrams, particularly in the context of two observers, Bob and Alice, who are in different inertial frames. Participants explore how these diagrams can mislead users if certain assumptions about spatial dimensions are not recognized, and they examine the implications for understanding events in spacetime.
  • Some participants note that while spacetime diagrams are useful, they can lead to misunderstandings if the audience is not aware of unstated assumptions regarding additional spatial dimensions (y and z axes).
  • One participant argues that the issue is not unique to spacetime diagrams but applies to any diagram that requires more dimensions for a complete description.
  • Another participant emphasizes that misreading diagrams is often due to the viewer's knowledge level and that assumptions can lead to incorrect conclusions about events.
  • There is a discussion about the correct interpretation of events in spacetime diagrams, particularly regarding when Alice sees an event that Bob describes, with some asserting that drawing 45° lines may not always yield correct results without considering additional dimensions.
  • Some participants express that while light travels on 45° worldlines in a 1D spacetime diagram, this does not imply that the situation being analyzed is limited to one spatial dimension.
  • Concerns are raised about the tendency to silently add assumptions to diagrams that are not explicitly represented, which can lead to misleading interpretations.
Participants generally agree that spacetime diagrams can be misinterpreted due to unstated assumptions, but there is disagreement on the extent to which this is a problem specific to spacetime diagrams versus a broader issue with any multi-dimensional diagram. The discussion remains unresolved regarding the implications of these misunderstandings.
Limitations include the dependence on the viewer's understanding of spatial dimensions and the potential for assumptions about y and z coordinates that are not represented in the diagrams. The discussion highlights the complexity of interpreting events in spacetime without complete information.
  • #31
PeterDonis said:
Which category a particular scenario falls into depends on whether there are events of interest that do not all lie along a single spatial direction. That's basically the upshot of this thread's discussion.
Well, that's your upshot, not mine. Yes, I've come to the conclusion that all of the things that I asked for will be variations of things that require the y and z coordinates. But I was hoping for some additional items to add to my list of three.
PeterDonis said:
In other words, you had in mind a case where person A and person B are the same person. How is the problem I described above, of person A getting misled because person B left out some relevant information when telling person A about the scenario, even possible if person A and person B are the same person?
Example:
Person A is learning about spacetime diagrams, sets up a Bob/Alice problem and diagrams it. Then person A adds an arbitrary event M and studies the diagram to find the (x, t) and (x', t') coordinates for the event. Person A has now extended the problem by adding to the diagram and has correctly extracted information from the diagram.
Person A adds event N and does the same thing. Then person A looks at angle of the line segment from M to N. Seeing that it is less than 45 degrees, person A concludes that this is a "space-like" interval. But person A starts to feel uneasy about it being this simple. Person A returns to the formula for determining if two events are space-like and realizes that the information on the diagram is insufficient; to use the angle in this way requires adding new information to the problem: that events M and N share the same (y, z) coordinates.
Another example:
Back in #7, I included a Bob/Alice diagram with event M. Looking at the diagram, person A might ask the question: "when does Alice see event A?" Person A might then get the bright idea then drawing the light worldline will answer the question. After some reflection, person A decides that this technique won't work unless the problem statement is extended to state that Alice and M share the same (y, z) coordinates.
These scenarios are quite possible (speaking from experience), but probably not if person A is Peter Donis.
The answers I'm getting (including from you) are along the lines of "your problem statement is wrong" or "you are using the wrong diagram." Well, duh! The OP was about enumerating cases that might seem reasonable but require that the problem statement be revised or that a different diagram be used.
  • #32
You already have the general rule. What's the point of enumerating more and more special cases?
Doesn't person A know what the y and z coordinates of event M are when they add it?
Same question as above.
Why didn't he realize that back when he specified the y and z coordinates of events M and N and looked to see whether they were the same?
Here person A is not you, which means it's not the case you said you were thinking of. Which case do you want to discuss?
I can understand how the scenario where person A and person B are different is possible, sure. I've already said so. But I also quoted a statement from you that said you were thinking of the case where person A and person B are the same person. I still am unable to understand how such a scenario as you described is possible if person A and person B are the same person. See my questions above.
  • #33
Because t's not always obvious that a special case falls under the general rule--that was why I asked it.
No. Person A just puts a dot on a diagram.
Same answer as above.
Because person A is not Peter Donis (or equivalent).
Bob is my name for the rest frame. Alice is my name for the moving frame. Person A is the only real person in all this.
You are confused--there is only one person involved in my last post. I've used the Bob/Alice terminology in several posts in this thread, including #7, but I can understand why you might have missed this.
The scenario is possible in the absolute sense that it I experienced it. Your inability to understand how the scenario is possible makes you a poor candidate for answering the question I asked.
  • #34
Then how is it even known what the y and z coordinates are? Person A is the one making up the scenario. He can't just punt and say someone else defined what the y and z coordinates are. There is no someone else. He's the only person involved. Either he defines the y and z coordinates, or the y and z coordinates don't exist and hence can't possibly be relevant to the problem.
So if you experienced it, surely you must have some answer to the questions I keep asking. When you defined event M, what y and z coordinates did you give it? Same question for event N. If your answers are "I didn't think of y and z coordinates at all", then how were you able to discover that the y and z coordinates of events M and N were even different? You can't say someone else told you, because you're the only person involved.
In short, while you can claim all you want that you experienced something, the way you are describing what you experienced doesn't make any sense with the information you've given so far. So either you're leaving information out, or you're simply not describing what actually happened correctly.
I don't see how you can expect anyone to answer questions about a scenario that doesn't even make sense.
  • · Replies 26 ·
  • · Replies 70 ·
  • · Replies 67 ·
  • · Replies 47 ·
  • · Replies 29 ·
