Can an undamped harmonic oscillator have a steady-state solution?
An undamped harmonic oscillator with no damping (b=0) subjected to an external force Focos(wt) does not have a steady-state solution when the frequency of the applied force matches the natural frequency (w=wo). The solution diverges as the limit # approaches 0, indicating that the system's response grows linearly over time without reaching a steady state. The characteristic equation must be derived to analyze the roots, which leads to understanding the system's behavior under these conditions.
  • Understanding of undamped harmonic oscillators
  • Familiarity with differential equations
  • Knowledge of sinusoidal forcing functions
  • Ability to derive and analyze characteristic equations
  • Study the derivation of the characteristic equation for second-order differential equations
  • Learn about the effects of damping on harmonic oscillators
  • Explore the concept of resonance in mechanical systems
  • Investigate solutions to forced oscillations in various physical systems
Students and professionals in physics, engineering, and applied mathematics who are analyzing dynamic systems, particularly those focusing on oscillatory motion and stability analysis.
Richardbryant
An undamped harmonic oscillator (b=0) is subject to an applied force Focos(wt). Show that if w=wo, there is no steady- state solution. Find a particular solution by starting with a solution for w=wo+#, and passing to the limit #->0, it will blow up. Try starting with a solution which fits the initial condition xo=0, so that i cannot blow up at t=0.
d^2x/dt^2+(wo^2)x=Fo cos(w+#)t/m
d^2y/dt^2+(wo^2)y=Fo sin(w+#)t/m
d^2z/dt^2+(wo^2)z=Foe^i(w+#)t/m (1)
Let Z=Ce^i(wo+#)t, plug in (1)
C=Fo/,[wo^2-(w+#)^2]
thus X= Fo cos(w+#)t/m[wo^2-(w+#)^2]
Xtr (trasient term )=Acos(wot-$) $= phase difference
After a couple of steps the final solution will blow up when limit #->0[/B]
With no damping and sinusoidal excitation at the undamped natural frequency, the solution grows linearly with time. This is the reason there is no steady state.
You need to obtain the characteristic equation and look at the roots. That will get you started toward the proper results.
What's your question?
Thanks for reply, i had been guessing the solution is also a trigonometric function , but it seems to be not working
The question is to find a x(t) satisfying the given condition
Obviously, that's what the question is asking of you. What is YOUR specific question? You seem to be on the right track.
Oh, yeah i got the correct answer, but i didn't notice, thank you about that!
Did you manage to show the system didn’t have a steady state solution?
10K
