Understanding Derivatives, velocity and acceleration
The discussion revolves around the concepts of average and instantaneous velocity and acceleration in calculus. It clarifies that the derivative of average velocity does not yield instantaneous velocity, as average velocity is a constant over time and its derivative would be zero. Instead, instantaneous velocity is obtained by differentiating the position function x(t), resulting in dx/dt. The confusion arises from the misunderstanding that the derivative of average quantities can represent instantaneous values, which is incorrect. Ultimately, the average velocity approaches instantaneous velocity only as the time interval approaches zero.
intenzxboi
I'm having a really hard time understanding this. So far this is what i think is correct.
V(average)= (X1-X0) / change in time
the derivative of V(average)= gives me the instant velocity ?
but at the same time say i have x(t), then the derivative of that is also the instant velocity?
A(average)= change in v / change in time
and if i take the derivative of A(average) i get instant Acceleration..
but then my teacher said that the derivative of V(average) = instant acceleration..
So does that mean that instant velocity= to instant acceleration??
No. It doesn't make sense to take the derivative of average velocity. The average would normally be over the whole time of the motion so it is a constant that does not vary with time - and its derivative would always be zero.
If you define avg V as (x(t) - x(0))/t so it DOES vary with time, then its derivative would be some very complicated quantity that doesn't have a name.
Yes, this is true. dx/dt is the instantaneous velocity or slope on the distance vs time graph.
Same problem here. Instantaneous acceleration is the derivative of instantaneous velocity. It doesn't make sense to differentiate averages.
The average velocity (not its derivative) will equal the instantaneous velocity in the limit as Δt goes to zero.
Vave = Δx/Δt
When Δt → 0, Δx/Δt → dx/dt = V (instantaneous)
o ok thank i think i got it
so unless average=to instant then the derivative does not apply in this case.
  • · Replies 27 ·
  • · Replies 23 ·
