Understanding Drag in Water: Calculation and Hypothetical Scenarios"
  • Thread starter Thread starter aosome23
    Water
To calculate drag in water, the formula used is 0.5 * velocity^2 * water density * Drag Coefficient * Cross Sectional Area, with velocity measured in meters per second. In a hypothetical scenario where a 1m³ cube hits water at 200m/s, the drag force calculated would be 50,000N. However, if the cube is lightweight, it would decelerate rapidly upon impact, and the drag force would decrease quickly, preventing it from bouncing back significantly. The discussion emphasizes that the direction of forces is crucial; drag acts opposite to velocity, and for the cube to be flung upward, its velocity must first change direction. Ultimately, the calculations must consider the rapid changes in velocity and force during the impact with water.
aosome23
Correct me if I'm wrong but to find drag for water you have to use this equation:
0.5 * velocity^2 * water density which is 1000kg/m^3 * Drag Coefficient * Cross Sectional Area
Velocity is supposed to be in m/s right? not km/h?
Okay so for example if there was an imaginary planet with no air and atmosphere, but only a large body of water(ocean). If a 1*1*1 meter cube was falling and it hit the ocean at 200m/s, the drag will be:
0.5 * 100m/s * 1000kg/m^3 * about 1 * 1m^2 = 50000
when it hits the water
If the cube is made out of really strong light weight material, wouldn't the cube get flung up? For example if the cube is only a gram. Is this even possible? When I think about it in my head, no matter how hard an object hits the surface of water, it would never bounce that much...
So anyways, i feel like I am misunderstanding something... Can someone help me?
The units do not matter, as long as you keep them consistent. If different quantities are given in different units, you'll have to convert some of them.
Don't forget units.
It would decelerate extremely fast and then come to a rest (approximately) - unless the cube itself is elastic, then it might bounce.
But if the force applied to the cube is 50000N wouldn't the cube be flung up because the mass is really small? So since force is m * a, if a cube is 1kg, that means that the acceleration will be 50000m/s^2. Since that is way larger than gravity which is 9.8m/s^2, wouldn't it make the cube fly up in the air? Or am I not calculating this correctly?
Force in what direction? You were asking about drag. That will be directed opposite to the velocity. In order to have a force upward to "fling" the cube upward the velocity must be downward. But as in order to go "upward" the velocity would have to change from downward to upward so must, at some point, be 0. As soon as that is true, there is no longer any drag force.
Likes 1 person
You are not thinking about this correctly. As soon as the cube starts to contact the water, it will decelerate very quickly, its velocity will drop rapidly, and the drag force will decrease very quickly. So the force on the cube won't stay anywhere close to 50000N for more than a minute interval of time.
Chet
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
