Understanding Fluid Velocity in a Restricted Pipe
  • Thread starter Thread starter kmkindig
    Idea
2 replies · 8K views · last reply
kmkindig
Liquid flows through a 4.0 cm diameter pipe at 1.0 m/s. there is a 2.0 cm diameter restriction in the line. What is the liquids velocity in this restriction?
I know that solution is 4.0 m/s but in don't know how to get there. Thank you
The concept one is concerned with here is continuity. For an incompressible fluid, the mass flow (rate) into a control volume must equal the mass flow (rate) out, otherwise mass would accumulate or decrease in the volume.
The mass flow rate is given by ρVA, where ρ is the fluid density, V is the mean (average) velocity and A is the cross-sectional area.
So we have ρVA(in) = ρVA(out), or ρVA(in) - ρVA(out) = 0, i.e. no net gain or loss of fluid (mass).
Now if ρ(in) = ρ(out), then the continuity equation becomes, V(in)A(in) = V(out)A(out).
Try apply this to given problem.
I know the answer is 4.0 m/s but I am not for sure how to get there. A little help would be greatly appreciated. Thank you!
There is a principle that states Av=constant, where A is the area of the fluid's path at a given time and v is the velocity.
Hence the answer is not 4.0 m/s, unless I'm wrong.
