Understanding Gears & Machines: Force & Distance
  • Thread starter Thread starter Jimmy87
    Gears Machines
This discussion centers on the mechanics of gears, specifically how they multiply force and speed. Participants clarify that the correct focus should be on torque rather than force, as torque is the product of force and radius. The confusion arises from the misconception that larger gears exert greater force; in reality, the forces between interlocking gears are equal, while torque varies with gear size. The conversation highlights the importance of understanding angular distance and torque in the context of gear systems, particularly in applications like bicycles.
  • Understanding of Newton's Third Law of Motion
  • Basic knowledge of torque and angular distance
  • Familiarity with gear mechanics and their applications
  • Concept of force as it relates to distance in mechanical systems
  • Study the relationship between torque and angular distance in mechanical systems
  • Learn about gear ratios and their impact on force and speed
  • Explore the mechanics of bicycles and how gear systems function
  • Review physics textbooks for accurate representations of gear mechanics
Students studying physics, particularly those preparing for GCSE exams, educators teaching mechanical principles, and anyone interested in understanding the mechanics of gears and their applications in real-world scenarios.
Jimmy87
I am really struggling to understand gears and how they can multiply force or speed. I was reading over this physics link (http://www.tutorvista.com/content/physics/physics-i/power-energy-machines/gears.php).
I'm confused about the whole "force x distance" idea. In this link it says cog A rotates twice for every turn of cog B so must be moving faster which I get. However it then talks about cog A moving twice the distance and so experiences half the force. My line of thinking is that the circumference is smaller on the smaller cog so although it is moving faster it is still covering the same distance as the larger cog in terms of circumference so then wouldn't the forces have to be the same? I thought the forces would be the same anyway because of Newton's 3rd law. Wouldn't a tooth of cog A exert a force on a tooth of cog B and cog B exert and equal and opposite force back on cog A?
I am not surprised the text at that link confuses you. It is nonsense.
Yes, the distances moved are the same, and the forces the gears exert on each other are the same (simple action and reaction).
The article should be discussing torque, not force. The purpose of meshing two gears of different sizes is to increase or decrease the torque.
Instead of force x distance it should look at torque x angular distance (which also equals work done).
Since the linear distance the gears move is the same, the gear with the greater radius rotates through a smaller angle, so experiences the greater torque.
Thanks Haruspex! The makes a lot of sense. The only thing that now confuses me is when people explain how this applies to bicycles. You have just confirmed that the linear distance must be the same on the two gears but the angular distance is more for the smaller gear. When people explain how low and high gears work they compare the LINEAR distance of the wheel (using its radius) to the LINEAR distance of the pedal. So if the wheel does 4 rotations for every one rotation of the pedal (small driving gear at the pedals and large driven gear at the back) the wheel covers more linear/circumference distance than the pedal. Why does linear distance work in this case but not in the example in the original post? In this second bicycle example can we now use "force x distance" to say when the wheel covers more linear distance there would be less force from wheel on the road and vice versa there would be more force required at the pedals and less linear distance?
Gears are connected in either of two ways: by meshing teeth (or, equivalently, sharing a chain that meshes with teeth on both), or by sharing an axle. In the former case, the linear distances are the same but the angular distances are different. In the latter case, the angles are the same and the linear distances differ. A gear train works by alternating the two cases. Going from the pedals to the wheel involves both.
Thanks again. After reading around more I am getting more and more worried. My textbook says the exact same thing as the website if I am understanding everything you have said. I took a picture of the start of the gears section from my textbook and attached it and would really appreciate it if you could quickly see if it is correct. It clearly shows two interlocking gears in figure 4 and that the larger gear with twice the diameter has twice the FORCE but shouldn't this be twice the torque and the SAME force for an interlocking gear? This is supposed to be the official textbook for our course! I am worried now what to do. Do I learn it the incorrect way?
Many thanks again!
Many thanks again!
You are right, this textbook commits the same blunder.
What textbook is it?
haruspex said:
Thanks for the link. I have written to OUP.
Thanks, hopefully it won't be in the exam just a textbook mistake. Although on the exam website it does say under that module "students should understand how ratios can enable gears and levers to work as force multipliers" so looks like could be on the exam like that as well. :(
Thanks for all your help haruspex ! :)
Thanks for posting this as my kids are also doing GCSE physics next year. I best check which exam board they are using to see if it's the same.
  • · Replies 19 ·
9K
  • · Replies 35 ·
  • · Replies 18 ·
  • · Replies 49 ·
