Understanding Induced Current and EMF in Electromagnetic Induction
  • Level: Undergrad
  • Thread starter Thread starter jsmith613
    Current
171 replies · 26K views · last reply
truesearch said:
Phew! I wonder what Faraday would make of that lot!
Your falling magnet in the copper tube...the induced currents flow around the tube but the current at the bottom is induced to repel the S pole, the one at the top is induced to attract the N pole.
Both currents are induced to generate S poles... They are in the same direction.
This is the difference between the tube with a falling magnet and the (thin) coil with a magnet falling through.
I think they are in different directions. Because they are acting to decrease the change in magnetic flux.
A S pole is needed at each end of the magnet to cause opposition to motion
look at the diagram on the previous page
it shows why currents are in different directions
BruceW said:
That is a different situation, it is measuring the emf along the entire coil.
so if I were to measure the emf across the entire tube (with the magnet falling) - assuming it were possible - would the current and emf be measured as zero?
I'm pretty sure emf between the top and bottom of the tube would be zero. In the case of the coil, an emf is measured when the magnet falls into it because the measured emf is effectively the total emf over the horizontal loops, so it will be non-zero when the magnet falls in (and out). But with the tube, you would be measuring the potential difference between the top of the tube and bottom, which will be zero. Its only if you had some other technology, or way of seeing the charge carriers that you would realize something is going on in the case of the tube.
jsmith613 said:
so you would agree then that the net EMF and current is zero?
You still need to define what you mean by "NET".
The only time I would use that term would be in a situation where, for example, forces on a point would Add Up to a 'net' or 'resultant value'. But these currents are all over the place so I think you must mean 'Mean Value' but Mean Value over what? Just the peak values? It is not as simple as you imply, I think. Decide what you really mean and we can come up with an answer.
just to absolutely clarify and then I think I have gotten it, the current too will be measured as zero between the ends of BOTH the coil and the tube, right?
well I mean the EMF/current across the ends of the tube / coil
I think maybe the word net / mean was a poor way of saying this
sophiecentaur said:
That diagram of the coil would suggest otherwise, wouldn't it?
sorry the diagram of the coil suggests exactly this...
I am off for tonight
we can carry on tomorrow
I continue to express my graditude for all the help you have been giving me (in fact if this is the first time I have said it I really do emphasise how grateful I am for all your help so far :)
For the case of the coil, when the magnet is falling into (or out of) the coil, there will be a flow of charge through the coil, to slow the rate of change of flux. But when the magnet is in the middle of the coil, the charges above the magnet want to go clockwise and those underneath the magnet want to go anticlockwise. But this would cause a charge separation, so when the magnet is in the middle, there is no flow of charge.
For the case of the tube, in reality there are lots of eddy currents that try to slow the rate of change of flux caused by the tumbling magnet. If the magnet went down smoothly as you've suggested, it seems plausible that there would be charges flowing anti-clockwise underneath the magnet and clockwise above the magnet (really they are just very ordered eddy currents). These eddy currents continue even as the magnet is falling through the middle of the tube.
In the coil, it is simple to measure the emf which causes the circular flow of charge, because of the fact that it is set-up as a coil. But in the tube, I can't think of a simple way of measuring the flow of charges, and if you just measured the emf between the top and bottom of the tube, I'm pretty sure you'd get nothing, or in any case it would not tell you about the circular flow of charge which is acting to decrease the magnet's acceleration.
Ah, I'm glad if I've even been of some help.
Edit: maybe you were just saying this to sophiecentaur... I am so quick to accept a thank you
The diagram has an oscilloscope trace in it which shows that the EMF is not Zero at all times. How can the following statement be right? Earlier you wrote this:
When is it measured as zero? You seem to have a problem with using the term 'Mean'. This is a bit of a handicap in discussions in which both time and position vary. Your term 'Net' doesn't make it clear what you want to say.
I am sorry but I have just followed an endless and frustrating thread, elsewhere, in which one of the contributors absolutely refused to use the right terms appropriately - mixing up force, strength, power etc. in a totally random way. The thread ended without his getting anywhere. I am very sensitive to this sort of thing at the moment, which is why I think the right terminology is important. Unless we agree on the terms to use and what they mean then we may not get anywhere either.
I am assuming you are familiar with the term?
what term??
absolutely this was aimed at you and everyone else who has helped me!
Oh I see
the question I was asking was for the entire time the magnet is INSIDE THE TUBE
obviously as it approaches / leaves there will be a change in flux BUT INSIDE THE TUBE the emf on the oscilliscope is zero.
look. the magnet is dropped from ABOVE THE COIL so obviously as it falls the emf will increase but my question was is it correct to assume that WHEN THE EMF IS ZERO, the current will also be zero
When I said MEAN/NET I meant WHILST THE MAGNET WAS IN THE TUBE
Right. Whilst inside the coil there is no induced EMF so the meter reads zero. This IS (and I see what you mean here) the NET instantaneous effect of the passage of the N and S poles along the coil length. They are only unbalanced when one pole is inside and one pole is outside the coil (at the ends).
Whilst the magnet is falling inside the tube there are EMFs being produced at all times which are producing circulating currents. Without the currents, the magnet wouldn't be slowed up, would it? These EMFs (and hence the currents) are in 'Lenz's Law' directions. BUT the Mean of all the EMFs around the magnet will be zero because both ends of the magnet are traveling at the same speed.
There is no reason to think that an EMF would ever be measured over the length of the tube because the axis of the tube (the conductor) is not at right angles to the direction of the motion. EMFs are induced around the circumference.
@Bruce You mention the problem of measuring the currents inside the tube. It would be possible to cut the tube, horizontally, half way down and insert an insulated split ring. You could measure the EMF across the gap in the ring and then this could 'indicate' the value of current, knowing the resistivity of the tube metal. The magnet would need to be not tumbling, of course.
Ok so I think you are saying that the mean emf will be zero but the mean current WILL NOT BE otherwise the magnetic field would not be produced, right?
As far as I'm concerned, as long as you ignore inductance (which you can), the current flowing in the coil of the tube will be directly proportional to the EMF. Where have I given the impression that they don't precisely track each other?
If current is flowing one way (because the emf is causing it to) in one part of the tube and in another direction in another part of the tube (for the same reason) then the mean current is zero but that doesn't imply that the Force on the magnet will be zero, does it? The currents at either end of the magnet must flow in opposite directions or the effect on one of the poles would be to PUSH the magnet down.
Are you reading elsewhere about Induction, RH and LH rules etc.? It may be a good idea because I think you may be mis-reading what I am writing at times. If you read someone elses way of putting things then perhaps it will make more sense to you.
All this stuff is so basic that it is available to read about all over the net. Have you ever tried the 'Hyperphysics ' pages? They are very good. I usually find something there for pretty well every topic.
ok thanks. I just wanted to check. I figured if the mean emf was zero and the mean current was zero I presumed no opposing magnetic forces would act. apparently this was wrong
Before I started this discussion I looked endlessly over the internet (including Hyperphysics, Wiki) for relevant infromation but as I am only studying A2 Level physics (and don't really want to study more complicated physics than this) I could not find anything.
The A2 websites were not detailed enough and other websites were too detailed.
its a hard balance
A level is strange these days. They spread the net wide and give you a taste of all sorts of new Physics topics*. This means you are spread much more 'thin' than when I did A level. I think it is bad for you because the course books never go far enough if you happen to get an interest in one particular topic. Have you access to a 'proper' textbook that was published a few years ago? You will probably find much better treatment of topics you find difficult. But you're talking £30+ rather than £10+ for a coursebook.The way to get good grades it just to LEARN every fact and formula in the specification (download it if you haven't yet) and then follow, step by step, the Exam questions, doing exactly what they ask. Needless to say, you have to be absolutely rock solid on the simple algebraic manipulation rules (re-arranging equations and the like) and the basic Trig formulae. That's where a lot of students are shaky.
*On the course that I taught (retired recently) they started AS Physics by talking about Fundamental Particles - loads of brand new ideas: "Particle Zoo" long before they dealt with how an electron behaves in an electric field. None of the students got anything out of it except the feeling that they 'knew about' some sexy particles. Totally fragmented.
well I am very good at maths (and do A2 maths).
I despise the way A-levels are structured...although the system is very easy to play with it means I come out not really knowing a lot of physics...i think this is why i dislike physics as a subject...the separate bits are fascinating but the way it is taught at A2 level means I learn some facts and just have to accept them.
anyway I would very much like to thank you and BruceW and everyone else who has helped me with this topic..hopefully if a question comes up I will be able to nail it :)
That's a good start!
That's because the course is aimed at 'bums on seats' and supposed to be attractive. I don't know how you got on at GCSE in Science but I know that very few of the students who chose Physics at A/AS had a clue about what they were letting themselves in for. It 'sounds good' as a subject (and of course it is) but it demands a level of rigour, even at A level, which many students have never come across before. As a consequence of student responses to past exam questions, the structure of the course has been adjusted to be suitable for students who don't particularly 'want to think'. Giving lots of taster units and not concentrating on some serious basics means that, as you say, you are given stuff which you have to accept as a fact and can answer questions adequately by just remembering the what, rather than the how. Way back, the topics we were taught were very conventional (heat, light, sound + elec) but, even in the first year, we got the message about how important the 'book-work' was. We had to be able to derive all the basic equations (of which there were a lot) and to REMEMBER them (not a single A level formula was given on the paper - just the constants). I have always told my students that if they need to look up a formula then they can't actually be sure that they will use it properly - after all, they are all pretty straightforward.
Having had my rant, however, I reckon that, if your Maths is good and you are interested enough to be worrying this particular topic to death (haha), then you should do all right. If and when you get to Uni to do Physics then you will find it is more suited to your attitude, I think.
Thanks, jsmith! I'm from uk too, and I recently finished my undergraduate physics degree. I'd say that A-level physics is a pretty good introduction to undergraduate-level physics (in case you're interested in doing that). The main difference is in how much maths goes on. There is definitely more maths involved in undergraduate physics than in A-level physics. And I think this is one of the main reasons that you must just accept some facts at A-level, because they simply haven't taught you the relevant maths yet. Also, they are trying to give you a broad view of physics, so it would take too long to go into detail.
I would very much like to check I have understood this topic:
here is the summary of the way I see everything working in relation to the COIL (I am ignoring the tube as it seems more complicated than needed for A-level)
is this summary correct
the net emf (across the entire coil) is zero when the magnet is in the coil so the current in the coil is also zero...but the current at either end of the magnet (above and below it) is creating an instantaneous magnetic field opposing the motion of the magnet as it falls (due to the currents that are present - i.e: before they cancel). This is for when the oscilliscope is attached - it completes the circuit
if we remove the oscilloscope then no current can flow as there is no complete circuit..hence there will be no opposing magnetic field and the magnet will accelerate due to gravity with no opposing forces AT ALL TIMES..
I really hope this is correct
NOTE: I will not be able to sign in until Sunday as I have a busy weekend so I will not respond to any comments until then. I would still be delighted for people to comment:)
Sort of... but an oscilloscope has 10Mohm resistance so you can say that no current flows!. If you were to short the ends together, you might get enough current to produce a measurable braking effect.
so it would be more correct to say that no breaking effect occurs inside the coil
but as it enters / leaves we will get current and hence breaking effect?
(inside the tube we DO get breaking effect due to eddy currents though, right)
The problem is that you start your A level course with GCSE Maths and not O level Maths, as I did and many people have just done Science GCSE Double Award. That effect trickles up all the way up to Degree level and this is why people are needing Masters Degrees to get the same cred as a good Hons degree in the dim and distant past. I guess, as all you young people are going to live till 100, an extra year doesn't actually hurt anyone. It's just the Politicians (****rds) who claim that kids are getting brighter as a result of their loony policies. Don't get me started on Synthetic Phonics. Grrrrr!
