Understanding Induced EMF: Basic Concepts and Doubts
The discussion centers on the concept of induced electromotive force (emf) in a superconducting loop when a magnet approaches it. Participants express doubts about the claim that the magnetic flux through the loop remains unchanged, arguing that the induced current and opposing magnetic field alter the net flux after the magnet's motion. It is noted that while the superconductor allows persistent current flow without resistance, this does not equate to a constant flux, as the induced emf responds to changes in magnetic flux. Clarifications are sought regarding the differences in induced emf behavior between superconductors and normal conductors, particularly concerning current magnitude and persistence. The conversation highlights the complexities of understanding induced emf in superconducting materials.
bksree
Basic question on induced emf - ATTACHMENT CORRECTED PLEASE RE-READ
Hi
Please read the attached doc which is excerpted from the text University Physics by Young & Freedman.The discussion is on the emf induced in a loop made of a superconducting material when a magnet is moved towards it.
Doubt 1
It is stated that 'the flux through the loop is exactly the same as it was before the magnet started to move'
Before the magnet moved the flux was downwards and due to the magnet. Once the magnet is moving emf is induced in the coil opposing the motion; so in this case the coil current is CW looking from above and the coil field now opposes the magnet field. Since the coil resistance is zero (superconductor) the current flows even after the magnet is stopped and so the net field after the magnet is stopped is the difference between the downward and upward fields which is NOT the same as the field before motion.
Doubt 2
It is stated that 'so the flux through a loop of zero resistance never changes'
In the above case the flux after motion is the difference between the downward and upward fields which is NOT the same as the field before motion (wherein the flux was downward).
Doubt 3
Is it possible (by adjusting coil radius and magnet motion) to have high current through the wire and net flux (coil flux due to induced current minus magnet flux)upward after motion
TIA
You are correct that the induced field in the loop will oppose the field of the magnet. However, you forget to include the fact that the magnet has moved closer to the loop, which means that there is more flux from the magnet contained within the loop (at least if you stop moving it before it passes through the loop). The induced flux will equal the amount of additional flux within the loop from moving the magnet closer. So although the loop field opposes the magnet field, the field within the loop from the magnet becomes stronger as the magnet approaches the loop.
krysith
Thanks for the reply. But my doubts remain :
(1) If the magnet is moved fast and brought to rest (without entering the coil) the rapid change in flux can induce very high current in the coil. Is it possible for this flux to be higher than the initial flux due to the magnet ? (Doubt 3)
(2) Initially the flux through the coil was was downward (due to magnet). After the above magnet motion, there is a running current through the wire (current continues to flow even after magnet is stooped because resistance is zero) and the net flux is the difference between the two fluxes (viz. due to magnet and that due to coil)(doubts 1,2). So the flux through the loop IS NOT EXACTLY THE SAME AS IT WAS BEFORE THE MAGNET STARTED TO MOVE
TIA
I think I understand now why you are having doubts. The infinitely low resistance is throwing off your physical intuition. Remember, you cannot use Ohm's Law to calculate the current in a superconductor. So thinking that a high rate of change of flux means a high induced voltage means a high current is not correct. The superconductor will only generate current to oppose any change in flux, regardless of the rate of change. Think of it like a mirror - it only shows you back what you show it.
Krysith
Thanks.
I wonder what the author means when he says
'Thanks to this persistent current it turns out that the flux through the loop is exactly the same as it was before the magnet started to move, so the flux through a loop of zero resistance never changes. '
and
'Then the induced current will continue to flow even after the induced emf has disappeared - that is, even after the magnet has stopped moving relative to the loop. '
In this case, in what way is the induced emf different in a superconductor vis-a-vis a normal wire ? only in the magnitude of current induced ?
Any explanations ?
TIA
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
