Why does kgm/s² equal a newton?
  • Level: High School
  • Thread starter Thread starter -Physician
    Newton
14 replies · 6K views
-Physician
Okay, so if we have the work Formula:
##A=Fd## we have units: ##N*m## which gives us joule ##J##,
but if we have the formula of the force:
##F=\frac{mv}{t}## we would have ##\frac{kg * \frac{m}{s}}{s}## which gives us ##kg \frac{m}{s^2}##, so does that give Newton?
Yes, because kg = mass and m/s^-2 = acceleration so... mass x acceleration = Force
So formula ##F=\frac{mv}{t}## gives us formula ##F=ma## or ##F=ma## gives us ##F=\frac{mv}{t}## ?
Looks OK to me. The dimensions are the same on both sides of the equation.
Why would you doubt this?
Science is consistent and full of little interesting bits like this. Enjoy.
That's about right, just the variation is missing. I assume that you know that acceleration is the variation of velocity over time. Dimensional analysis doesn't provide that kind of information.
Newton's second law is that F ~ dp/dt with p=mv
How not??
Acceleration: ST-2
sophiecentaur said:
How not??
Acceleration: ST-2
Again: it doesn't provide the information about v/t vs. dv/dt.
Same units same dimensio. Even same value for uniform acceleration. What probem do you have?
I have no problem.
[tex] \frac{d v}{d t} = \lim_{\Delta t \rightarrow 0} \frac{\Delta v}{\Delta t} = \lim_{\Delta t \rightarrow 0} \frac{v(t + \Delta t) - v(t)}{\Delta t}[/tex]
Now, look at the numerator (angle brackets mean dimension of ...):
[tex] \left[ v(t) \right] = \left[ v(t + \Delta t)\right] = \left[ v \right] \Rightarrow \left[ \Delta v \right] \equiv \left[ v(t + \Delta t) - v(t) \right] = \left[ v \right][/tex]
where we had used the rule from Dimensional analysis that one can only add and subtract physical quantities with the same dimension, and the result is of the same dimension.
Next, look at the fraction:
[tex] \left[ \frac{\Delta v}{\Delta t} \right] = \frac{\left[\Delta v \right]}{\left[ \Delta t \right]} = \frac{\left[ v \right]}{\left[ t \right]}[/tex]
where we had used the rule of Dimensional analysis that the dimension of a product or ratio of two physical quantities is the product or ratio of their dimensions.
Even if you take the limit as [itex]\Delta t \rightarrow 0[/itex], the dimensions of the ratio do not change. So:
[tex] \left[ \frac{d v}{d t} \right] = \left[ \frac{\Delta v}{\Delta t} \right] = \frac{\left[ v \right]}{\left[ t \right]}[/tex]
This is a general rule: The dimensions of a derivative of y w.r.t. x is simply [y]/[x].
sophiecentaur said:
But you claim that Dimensional Analysis doesn't work in calculus?
No, not at all. I simply warned the OP that v/t is not identical to dv/dt. For example, if m=1, v=1, t=1, F =/= 1 (except by pure chance) :rolleyes:
I think it was you who brought DA into it and you seemed to be 'dissin' it. All you were really doing was questioning the accuracy resulting from some assomptions? I'll buy that.
No, it wasn't me - and let's hope that the OP gets it. :smile:
