Understanding Polar Coordinate Integration
28 replies · 4K views
xstetsonx
can someone explain to me why my teacher divided the area into two?
I=[tex]\int[/tex]1,0[tex]\int[/tex](2x-x^2)^.5,0 1/(x^2+y^2)^.5dydx
ugggggh i tried to use the latex...
anyway...
he used the polar coordinate to do this. once he turned it into polar coordinate, he divided the area into 2 bounded by (pi/4 - o d[tex]\theta[/tex]) (1/cos[tex]\theta[/tex] - 0 for dr) and then + (d[tex]\theta[/tex] bounded by pi/2 - pi/4) (2cos bounded by 2 - 0)sorry i don't know how to make this more clear...ask me if you need to clarify
see the correct (hopefully) tex below, click on it to see script, note you can put the whole equation in one set of tags
[tex]\int_0^1 \int_0^{\sqrt{2x-x^2}} \sqrt{x^2+y^2} dy dx[/tex]
is this what you meant?
I think it might actually be
[tex]\int_0^1 \int_0^{\sqrt{2x-x^2}} \frac{1}{\sqrt{x^2+y^2}} dy dx[/tex]
my teacher said you have to separate the area into to parts in order to solve it and i don't understand whysorry about my crappy drawing again
The region over which integration takes place is the upper left quarter of a circle with radius 1 and centered at (1, 0). When you switch to a polar integral, the description for r changes, and this is why you need to write the polar form of your given integral with two integrals. For one integral, r ranges from 0 to the appropriate value on the line x = 1. For the other integral, r ranges from 0 to the appropriate value on the circle.
then how you suppose to figure out the boundaries? and can you expand on the description for r changes??
Enters Mark! You're in much better hands than mine now xstetsonx so I'm definitely stepping back here. Have fun! :smile:
Have you drawn a sketch of the region? I have described the boundaries. All you need to do is change the Cartesian equation that represents each boundary to its polar form.
yup under the attachment above. well you said appropriate i am not clear. my teacher he
said for d[tex]\theta[/tex] is from 0 to pi/4 for the first one...etc i don't understand how you get this value according to that graph
The graph in your attachment is not very useful, as the circle part doesn't look much like part of a circle, and almost nothing is identified with its equation. To answer your question, what are the coordinates of the point where the vertical line intersects the circle? For the same point, what are the polar coordinates?
1? cos^2+sin^2?
No. Polar coordinates are pairs of numbers (r, theta), with the first being the distance from the pole (origin) and the second the angle theta.
In any case, cos2(x) +sin2(x) is identically equal to 1.
MARK you are once again the awesomest guy on here
thanks a lot
yup yup everything makes lot senses now but i just want to know how he get the equation 1/cosx and 2cosx
if i am doing from scratch how do i know it is that equation?
Equations have = in them, and I don't see any.
The line x = 1 (one boundary of the region of integration) can be converted to polar this way:
r*cos(theta) = 1 ==> r = 1/cos(theta) = sec(theta).
The circle's equation is x^2 + y^2 = 2x. Converting to polar, you get this:
r^2 = 2rcos(theta) ==> r = 2cos(theta), which I get by dividing both sides of the first equation by r.
thanks a lot
Told you he's a legend! His input to homework threads (not necessarily my own) has helped me on more than one occasion.
Anyway, I'm waaaay off topic here! :biggrin:
