Understanding Pressure Drop Calculations in Fluid Mechanics
The discussion revolves around calculating pressure drop in fluid mechanics, specifically focusing on a problem involving water flow in a smooth pipe. The original poster is exploring the application of the Hagen-Poiseuille equation and the implications of laminar versus turbulent flow.
  • The original poster attempts to apply the Hagen-Poiseuille equation but questions its validity due to uncertainty about the flow type and pipe characteristics. Participants discuss the importance of determining whether the flow is laminar or turbulent, suggesting the calculation of the Reynolds number as a necessary step. There are inquiries about the meaning of 'smooth pipe' and its implications for flow assumptions.
Participants are actively engaging with the problem, with some providing clarifications on concepts such as head loss and the relationship between head and pressure. The original poster has made progress by calculating the Reynolds number and recognizing the need to switch to the Darcy-Weisbach equation for turbulent flow. There is no explicit consensus on the final approach, but guidance has been offered regarding the methods applicable to different flow regimes.
Participants note the lack of information regarding the pipe's bends and the specific roughness of the material, which may affect the calculations. The original poster expresses confusion about the lecturer's comments on calculating pressure multiplied by heads, indicating a need for further clarification on terminology and concepts.
kachi
Hello. I have had an attempt at solving this pressure drop problem, but I have been told it is incorrect.
I am very much a beginner in the area of fluid mechanics, so if you could please define any terms that you are using, that would be so helpful!
I thought using the Hagen-Poiseuille would fit, as the question has given data that would fit into the equation and it also suggests that the pipe is laminar (smooth pipe). Although, it does not state whether the pipe has bends or is just straight. Does 'smooth pipe' also mean 'straight pipe'? Do I assume its straight?
Why is my attempt wrong? What are the other possible ways to solve this/pressure drop?
The lecturer I asked said that this method wasn't right, and that I should just calculate pressure multiplied by all the heads (pressure x heads). I still am confused by this though.
Also, am I allowed to ask more questions relating to my given question in this thread?
The question is below:
Water at 20°C flows in a 35 cm diameter smooth pipe at a rate of 0.0476 m^3/s from the Goulburn River to the Holding tank. What is the frictional head lost* (in m) and corresponding pressure drop (in kPa) per 100m length of pipe?
EDIT: *I didn't see this part of the question...
Known data:
  • Water has a temperature of 20°C
  • Diameter of pipe is 35cm
  • Flow rate is 0.0476 m^3/s
  • Length of pipe is 100m
Hagen-Poiseuille equation:
Where:
ΔP is the pressure loss
L is the length of pipe
μ is the dynamic viscosity
Q is the volumetric flow rate
d is the diameter
Pi is the mathematical constant Pi
Using:
Where:
ΔP is the pressure loss (Pa) = ?
L is the length of pipe (m) = 100m
μ is the dynamic viscosity (Pa*s) = 1.002 for Water @ 20°C
Q is the volumetric flow rate (m^3/s) = 0.0476 m^3/s
d is the diameter (m) = 0.35m
Pi is the mathematical constant Pi Attempt:
ΔP = (128(1.002 Pa*s)(100m)(0.0476 m^3/s))/pi(0.35)^4
= 12949.786 Pa
ΔP = 12.95 kPa/100m
Pressure drop is 12.95 kPa per 100m length of pipe.
Thank you very much in advance. I appreciate it.
'Smooth pipe' does not mean 'straight pipe'. The absolute roughness of a pipe is a measure of the irregularities in the inner surface of the pipe, and different materials have different roughness values. The ratio of the roughness of the pipe material to the pipe inside diameter is an important factor in establishing how the fluid flows thru the pipe.
http://www.enggcyclopedia.com/2011/09/absolute-roughness/
I don't understand your last sentence. 'Head' is equivalent to 'pressure', just expressed in a different form. Multiplying head x pressure is meaningless.
The Hagen-Poiseuille equation is valid only if the flow in the pipe is laminar. Do you understand how to determine if the flow is laminar? Have you calculated the Reynolds number for your flow problem?
http://en.wikipedia.org/wiki/Hagen–Poiseuille_equation
To answer your original question, yes, there are other methods of calculating pressure drop, depending on whether you have laminar flow, fully turbulent flow, or something in between.
You can ask as many questions as you want pertaining to your problem, if you don't understand everything posted in the responses.
Thank you for your response. Oh ok so head is just another name for pressure. I see.No, how do I determine if a flow is laminar?
I was reading a webpage saying that laminar flow is 'smooth' and 'turbulent' flow is 'rough'. Is this description true?
http://en.wikipedia.org/wiki/Laminar_flow
In order to solve this question, is the first step to find what type of flow it has?
Do we have to calculate and obtain a value to see whether a flow is laminar or turbulent? Is this what the Reynolds equation is for?
Sorry for all the questions
The Reynolds number calculation is key to determining if your flow is laminar or not. Laminar flows have Reynolds numbers below about 2300. For circular pipe, the Reynolds No. is:
Re = v*D*ρ/μ where,
v = velocity of the flow, m/s
D = inside diameter of the pipe, m
ρ = density of the fluid, kg/m[itex]^{3}[/itex]
μ = dynamic viscosity of the fluid, Pa-s
'Laminar' flow is where the flow of the fluid occurs with no mixing between layers. As the flow increases velocity, mixing between layers will begin to occur, and the flow is said to become 'turbulent'.
Thank you very much again.
I tried the problem again earlier, it's a bit long though:
$$ N_R = V D \rho/μ$$
Where,
N_R = Reynolds number
V = Velocity of flow, 0.4947m/s
D = Diameter of pipe, 0.35m
ρ = Density of water at 20°C, 998 kg/m^3
μ = Dynamic Viscosity, 1x10^-3 Pa*s
Reynolds Number = ((0.4947 m/s)(0.35m)(998 kg/m^3))/1x10^-3 Pa*s
= 172798.7
As Reynolds number > 4000 the flow is turbulent
As the flow is turbulent, I would need to find the relative roughness of the pipe.
Relative Roughness = ε/D
Where,
ε = roughness of the 'smooth pipe', 0.0m (assuming 'smooth' is either plastic or glass)
D = diameter of pipe, 35m
Relative Roughness = 0.0m/35m
= 0.0
I have the Reynolds number (172798) and the Relative roughness (0.0).
Using the Moody diagram, I get a frictional factor of around 0.027.
Frictional Factor = 0.027
I figured out that I can't use that Hagen-Poiseuille equation as it is only for laminar flow? I learned that for the flow to be laminar the Reynolds number < 2000.
I'm using Darcy–Weisbach's equation for head loss.
$$H_L = f (L/D) (V^2/2g)$$
Where,
H_L = Head Loss
f = frictional factor, 0.027
L = Length of pipe, 100m
V = Velocity, 0.4947m/s '
g = gravity due to acceleration, 9.81m/s^2
H_L = 0.027 * (100m/0.35m) * (0.4947m/s)^2/(2*9.81 m/s^2)
= 0.0962m
Head Loss is 0.0962 metres.
To find the pressure drop can I just convert the head loss (m) to pressure drop (kPa)?
Since you said that head loss = pressure?
Head Loss --> kPa
P = SG * g * h
Where,
P = Pressure (kPa)
SG = Specific Gravity of Water at 20°C, 0.998
h = Head Loss
P = 0.998 * 9.81 m/s^2 * 0.0962m
= 0.941 kPa/100m of pipe
So the pressure drop is 0.941 kPa per 100m of pipe?
Is this right? I still can't picture these measurements in real-life to know if it's close the right answer...is the pressure and head loss too small?
Re = v*D*ρ/μ where,
Your numbers look OK to me.
Ok thank you for your help! I appreciate it.
  • · Replies 16 ·
  • · Replies 38 ·
