Understanding TE Mode in Waveguides: Effects of Linear Polarization
  • Thread starter Thread starter radonballoon
    Mode Waveguides
The discussion focuses on the behavior of linearly polarized waves in waveguides, particularly in TE mode. When a linearly polarized wave enters a perfect conductor waveguide with its electric field parallel to the waveguide, it scatters and does not enter. In contrast, a good conductor allows some wave penetration, but most of it is rapidly attenuated. The relationship between the Poynting vector and the electric field is clarified, emphasizing that they can be oriented differently while still being parallel to the waveguide. Overall, the interaction of linearly polarized waves with waveguides is influenced by the conductor's properties and the orientation of the electric field.
radonballoon
So we just went over waveguides in my class, in particular the TE and TEM modes (for a perfect conductor with two infinite planes for waveguides). I know that according to boundary conditions (assuming perfect conductor), the transverse electric field components must be zero at the boundary. This means that for a linearly polarized wave, the wave vector must be at an angle for TE mode. My question is: what exactly happens when a linearly polarized wave enters parallel to the waveguide with the electric field polarized parallel to the waveguide as well? Does the wave simply not enter the waveguide? Does the wave change direction? Thanks
For a perfect conductor, the wave scatters and doesn't enter guide.
For a good conductor, some of the wave enters but is rapidly attenuated, and most of the wave is scattered.
How can a linearly polarized plane wave with the Poynting vector parallel to the waveguide enter the wavegiude and have its electric vector also parallel to the waveguide. What wavelength is it? What size waveguide?
thanks, that clears it up. I figured that's what would happen, but I wasn't sure.
To other poster: The poynting vector can be pointing in say the z direction and have the electric vector pointing in -x direction (magnetic field in -y direction). Then if the waveguide (two parallel planes) was in the x-z plane, they would both be parallel to it. I don't think frequency of the incoming wave matters much in what I'm asking either.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
