Understanding the Metric Tensor in General Relativity
14 replies · 4K views
dianaj
Hi all,
I have just started learning about general relativity. Unfortunately my book is very math-oriented which makes it a bit challenging to understand the content from a physical point of view. I hope you can help. :smile:
I am familiar with special relativity theory and Minkowsky Space. As I understand it the most simple version of the metric tensor, g, is used to describe this flat space.
If a pick a point in a gravitational field the space around it curves. Unlike flat space we can only consider a very small section around this point, in order to make the space around it seem flat, right? But if the small section is very-nearly-flat why not use the equation from Minkowsky Space to describe it?
I am referring to this equation:
[tex](d\tau)^2 = c^2(dt)^2 + r^2[/tex]
I mean, what is the point of zooming into make it look flat if it is not treated as flat space anyway?
If space is curved the metric tensor becomes a lot more complex and the equation becomes:
[tex](d\tau)^2 = -g_{\mu\nu}dx^{\mu}dx^{\nu}[/tex]
Am I right when I say that the equation describes processes in a very small, free-falling nearly-flat-but-still-curving section around a point in a big(ger) gravitational field? That g is not simple anymore due to the curvature in this small section? And that the point of view is that of a free-falling observer in that exact point?
And here is a bonus question: if a free falling observer (or the very small section) does not feel gravity why does he still percieve the space as curved?
Thank you in advance,
Diana
Hi Diana; welcome to Physics Forums!
Which book are you using?
Typo? In a curved spacetime, coordinates can be set up such that the metric has Minkowski form at any single event. Even in these coordinates, the metric will look different away from the chosen event.
Then, things look close to the special relativistic case, and intuition built up using special relativity often (but not always) can be applied.
Any point of view is possible, freely falling, or non-freely falling.
Non-zero curvature manifests itself in the form of tidal effects in any extended region, no matter how small, of spacetime.
the minkowski metric is [tex](-1,1,1,1)[/tex] (with c taken to be 1)
in general, the line element is [tex]d\tau^2 = -g_{\mu\nu}dx^{\mu}dx^{\nu}[/tex]
so in minkowski space, the line element becomes [tex]d\tau^2 = -dt^2 + dx^2 + dy^2 + dz^2[/tex] (which is what i think you are referring to in the equation above involving r)
the 'complexity' of the line element depends really on the metric chosen.
not quite sure what the question is about zooming is but http://en.wikipedia.org/wiki/Minkowski_space#Locally_flat_spacetime" makes sense.
wikipedia said:
Locally flat spacetime
Strictly speaking, the use of the Minkowski space to describe physical systems over finite distances applies only in the Newtonian limit of systems without significant gravitation. In the case of significant gravitation, spacetime becomes curved and one must abandon special relativity in favor of the full theory of general relativity.
Nevertheless, even in such cases, Minkowski space is still a good description in an infinitesimally small region surrounding any point (barring gravitational singularities). More abstractly, we say that in the presence of gravity spacetime is described by a curved 4-dimensional manifold for which the tangent space to any point is a 4-dimensional Minkowski space. Thus, the structure of Minkowski space is still essential in the description of general relativity.
In the realm of weak gravity, spacetime becomes flat and looks globally, not just locally, like Minkowski space. For this reason Minkowski space is often referred to as flat spacetime.
ok here is another related question, if you plug the properly signed kronecker delta (sorry don't know the correct term) as the metric tensor into the GR equations you get Minkowski space, correct? Some curvilinear metric tensor is then what would differentiate general from special relativity?
perhaps I'm wrong but i'd imagine that if we include time, then
kronecker delta = (1,1,1,1)
mikowski metric = (-1,1,1,1)
so no, you don't end up with minkowski space.
if you take time out of the equaton, then yes, the two are the same but this is not really any help is it?
ah. you said 'properly signed kronecker delta'... i presume you mean the minkoswki metric? :)
yes, you would get minkowski space then alright.
yes, that's what I meant with the -1,1,1,1, on the central diagonal of a 4x4 matrix
so another question, what determines a valid metric in curved space? because its a tensor by definition you could convert minkowski space in a covariant transformation to, say, 4-dimensional spherical coordinates and back again without moving outside of special relativity - analogous to the transformations in any introduction to tensor calculus and not have curved spacetime. Is it the fact that the covariant derivative would in that case be zero, wheras with a "real" curvature you would have to contend with the christofel symbols?
It's actually http://www.nbi.dk/~polesen/GRC.pdf" (course starts in september but I can't wait :wink:). If you could recommend a book to read on the side I would be very happy.
Ah, I think that's where I went wrong. I think I somehow got it into my head, that the equations only describe processes as a free-falling observer would see it. But this is not true.
I think what confused me was that the book started with small free-falling elevators, but I have realized that this was only to derive the more general equations.
Thank you for your answers.
Thanks, Naty and dianaj. I've downloaded them both.
In a sufficiently small region of space (the limit as space and time displacements go to zero) spacetime may appear flat. In a freely falling reference frame you can apply the Minkowski metric at some point. Visually, think of a flat 2D Minkowski spacetime tangentially intersecting a curved 2D spacetime surface at a single point.
The curvature of spacetime enters into relativity by considering first and second derivatives of the metric with respect to displacement. So, though the metric can be Minkowski, derivatives of the metric are not.
In your notes, dianaj, curvature starts-in at equation 1.74. To me, the text looks a little too fast--too much of an outline. In the defense of the author, I only took a very brief look, though.
You might want to take the bold step and change texts. This, I believe, is by far the best online text available:
http://xxx.lanl.gov/abs/gr-qc/9712019"
In a curved spacetime, coordinates can be set up such that the metric has Minkowski form at any single event P, and such that at P, all the first derivatives of the metric with respect to coordinates are zero (page 50 of Carroll's on-line notes). Such coordinates are called local inertial coordinates.
I don't see anything in Sean Carroll's Lecture Notes on General Relativity (Dec 1997) page 50, or even pages 48-52 to indicate that the fist derivatives of the metric are zero in Riemann normal coordinates, or any other singled-out coordinate system. Can you give a specific equation number to better substantiate this? Otherwise I will be forever wondering how you came to this conclusion.
It's in between eq. 2.34 and eq. 2.35.
My personal favourite, comprehensive introductions to general relativity are given in
https://www.physicsforums.com/showthread.php?p=2264023#post2264023.
Note that "physics first" and "math first" do not refer to emphasis, they refer to order in which topics are presented. Both of the GR books to which I refer in the link emphasize physical applications.
Sean Carroll's on-line notes are quite good, and his published book Spaetime Geometry: An Introduction to General Relativity (based on the notes) is even better. Carroll offers valuable and interesting insights into GR, but I think most, but not all, people looking for introductions to GR would benefit more from other books.
Daverz has already given the location, but to narrow things down further, start with the first full sentence on page 50. In on-line notes, Carroll gives a references Shutz for construction of these coordinates, but on pages 112-113 of his published book, he uses more sophisticated methods to construct the coordinates than does Shutz. I love Carroll's book.
Thanks George and Daverz.
