Understanding the Relationship between Ln and e^x
5 replies · 6K views
Tricky557
I'm just not sure what the answer to this is. I think it's an identity for e^x and ln, but I've never had a course that dealt with e^x or logs. So I don't know.
What is the answer to e^14ln(x)? It's part of a larger problem, but I can't get the rest of it done until I know that.
None.
I think the answer is x^14. But I'm not sure.
Well, what was your reasoning?
Aside: when you're writing linearly, be careful about parentheses! The expression
e^14ln(x)​
means
[tex]e^{14} \ln(x)[/tex]
whereas
e^(14ln(x))​
means
[tex]e^{14 \ln(x)}[/tex]
Yes, sorry about that. I did mean to write:
e^(14*ln(x))
I was thinking, that if I equated some random variable(say y) to e^(14ln(x)), then I could just solve that equation.
y= e^(14*ln(x))
lny= 14lnx
lny = 14lnx
lny = ln(x^14)
e^ of both sides
y = x^14The part of that I am unsure about is:
Does 14lnx = ln(x^14) ?
Yes, that works, so you can see that by definition, elnx = x. Also, a*lnx = ln(ax)
e^(14*ln(x))
That's not the best approach. The intended goal of this problem is for you to simplify the given expression. Setting your expression equal to, say, y, doesn't help much to move things toward your goal of simplification.
Use the properties of logs and exponents to rewrite your expression in a different (and simpler) form.
Tricky557 said:
y= e^(14*ln(x))
lny= 14lnx
lny = 14lnx
lny = ln(x^14)
e^ of both sides
y = x^14
Yes.
Thanks for the help!
