Understanding the Speed of Light in Ether: A Historical Perspective
The discussion centers on historical perspectives regarding the speed of light in the context of ether theory prior to Einstein's contributions. Participants explore the implications of classical ether theory and Maxwell's equations, as well as the philosophical questions surrounding the nature of light and reference frames.
  • Historical
  • One participant suggests that before Einstein, it was believed that the speed of light in ether was constant and independent of the motion of the source, implying that an observer at rest with respect to ether would measure the speed of light as c.
  • Another participant points out that the term "photon" is anachronistic for discussions about pre-1905 physics, suggesting the use of "flash of light" or "light signal" instead.
  • A participant notes that classical ether theory posited a constant speed of light in the ether's rest frame, while Maxwell's theory indicated that the speed of light was the same in all reference frames, again in the absence of matter.
  • There is a question raised about whether everything is at rest with respect to a flash of light, to which another participant responds that it is not possible to define a frame where light is at rest.
  • Mentors have removed off-topic discussions regarding Lorentz ether theory, clarifying that it is a different theory than the historical ether theory being discussed.
  • One participant mentions their class assignment, which involves comparing pre-Einstein and post-Einstein views on physics, indicating a focus on historical context.
Participants express some agreement on the historical understanding of light speed in ether, but there are also competing views regarding the implications of Maxwell's theory and the nature of reference frames. The discussion remains unresolved on several points, particularly regarding the interpretation of light's behavior in relation to different frames of reference.
There are limitations in the discussion regarding the definitions of terms used, as well as the historical context of theories that may not be fully explored. The removal of off-topic posts indicates a focus on specific historical theories rather than broader discussions of ether theories.
Luis Babboni
Hi people!
May be this could be an historical question.
Before Einstein, it is suppoused that speed of light in ether is always the same, I´m right?
I mean, if observer O is at rest respect ether and observer O´ is moving respect ether and O´ send a photon to O, the speed at which that photon arrives O (measured by O) is c cause, as I said, O is at rest respect ether? That is that the speed of O´, the source of the photon, must not be added to c.
Thanks for comment.
If you're going to talk about what physicist believed before 1905 you will have to pretend that you never heard the word 'photon"... but you can substitute the more appropriate phrases "flash of light" or "light signal" and your question still works.
And with that correction the answer is "yes". However, this answer is inconsistent with the negative result of Michelson-Morley experiments, and that's how we ended up where we are.
Thanks Nugatory! :-)
According to the classical ether theory the speed of light was always the same in the rest frame of the ether (in absence of matter).
According to Maxwell the speed of light was the same in every frame of reference (again in absence of matter).
"According to Maxwell the speed of light was the same in every frame of reference (again in absence of matter)."
Good point!
Thanks DrStupid!
Mentor's note: Several off-topic posts about the Lorentz ether theory have been removed from this thread. Despite sharing the word "ether", this is a substantially different theory (not falsified by Michelson-Morley experiments) than historical ether theory that the original poster was asking about.
Even if it were on topic in this thread, we generally do not allow discussion of the LET: https://www.physicsforums.com/insights/pfs-policy-on-lorentz-ether-theory-and-block-universe/
Does that mean everything is at rest with respect to a flash of light or light signal?
No. It turns out to mean (coupled with the principle of relativity) that there is no such thing as "with respect to light". You can't define a frame where light is at rest.
The reason I asked about it is cause in our class we have a first practice that ask we what previous to Einstein physics thought about some things and then in following practices we must found what after Einstein physics thinks about the same things.
There is some discussion on the history leading up to Special Relativity in this chapter of this book.
Thanks!
  • · Replies 34 ·
  • · Replies 25 ·
  • · Replies 42 ·
  • · Replies 72 ·
