Understanding why change in Kinetic Energy is 0
The discussion centers on the application of the Work-Energy Theorem in a physics problem involving two masses, M1 (3Kg) and M2 (5Kg), with coefficients of friction μ1 (0.4) and μ2 (0.6). The key conclusion is that the change in kinetic energy (ΔK.E.) of M1 is zero when M2 is about to move, as M1 remains at rest until the required force from the spring is achieved. The confusion arises from the integration of Hooke's law to derive the force, rather than directly applying it, which is deemed unnecessary once the spring's compression is sufficient to initiate M2's movement.
  • Understanding of the Work-Energy Theorem
  • Familiarity with Hooke's Law and spring mechanics
  • Basic knowledge of friction and its coefficients
  • Concept of kinetic energy and its changes in motion
  • Study the Work-Energy Theorem in detail, focusing on its applications in mechanics
  • Learn about Hooke's Law and how to apply it in various scenarios
  • Explore the relationship between force, mass, and acceleration in physics problems
  • Investigate the effects of friction on motion and how to calculate it in different contexts
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of energy and motion in physical systems.
Better WOrld
Find the minimum force ##\displaystyle F## required to move ##\displaystyle M_2##.Details and Assumptions:
##\displaystyle M_1 = 3Kg##
##\displaystyle M_2 = 5Kg##
##\displaystyle \mu_1 = 0.4##
##\displaystyle \mu_2 = 0.6##
##\displaystyle g = 9.8m/s^2##
[/B]
The solution suggested is as follows:
Let ##\displaystyle M_1## be displaced by a small distance ##\displaystyle x##
Using the Work energy theorem,
$$\displaystyle Fx - \mu_1M_1gx - \frac{1}{2}Kx^2 = \Delta K.E.$$
For the situation that ##\displaystyle M_2## just moves,
##\displaystyle \Delta K.E. _{M_1}= 0##
However, I cannot understand why the change in Kinetic Energy of M1 should be 0. How do we know that when M2 is just about to move, M1 will be at rest?
I've been troubled by this doubt for ages and would be really grateful if somebody would kindly explain the reason to me in detail. Many many thanks in advance!
It is baffling to me why someone would invoke the work energy theorem here. It appears that the approach is to use spring energy computed by integrating Hooke's law (F=kx) over distance to obtain energy (E=1/2kx^2) and then to differentiate that (hence the "small distance x") to obtain force.
Why not do it the easy way and simply compute force from Hooke's law directly?
Edit: Never mind me. I see I've misunderstood the scenario. The optimal scheme involves getting M1 up to a decent speed.
Sir, please could you explain why ##\Delta K=0##?
To move M2 you require a certain force exerted by the spring. That corresponds to a certain compression of the spring. Once that compression is reached, M2 will move - you do not need any further compression. So you only need to move M1 far enough to achieve that compression.
Thanks very much Sir. Sir. please could you help me with another question too?
https://www.physicsforums.com/threa...ing-on-an-inclined-plane.833831/#post-5235629
  • · Replies 58 ·
  • · Replies 20 ·
