Uniform Continuity of functions
40 replies · 6K views
Bling Fizikst
below
below
Discuss uniform continuity of the following functions:
##\tan x## in ##[0,\frac{\pi}{2})##
##\frac{1}{x}\sin^2 x## in ##(0,\pi]##
##\frac{1}{x-3}## in ##(0,3),(4,\infty),(3,\infty)##
I am completely new to this uniform continuity and couldn't find a lot of examples to learn the solving pattern .
For the first problem , i tried to use the definition ,
for ##x,y## in the given interval , ##|x-y|<\delta\implies |\tan x-\tan y|=\frac{|\sin(x-y)|}{|\cos x\cos y|}\leq \frac{1}{|\cos x\cos y|}##
Just stuck in this and the other problems .
If you are stuck trying to show uniform continuity of the function, try to show that the function is NOT uniformly continuous.
Continuity is a local phenomenon. It always means continuous at a point ##x_0.## The usual definition is that for every ##\varepsilon >0## there is a ##\delta >0## such that ##|f(x)-f(x_0)|<\varepsilon## whenever ##|x-x_0|<\delta.##
If you look closer to that definition, then you will find out that ##x_0## is chosen prior to ##\delta## as is ##\varepsilon.## This means that it actually should have been written as:
\forall\;\varepsilon>0 \;\;\exists \;\delta(x_0,\varepsilon) \, : \, |x-x_0|<\delta(x_0,\varepsilon) \Longrightarrow |f(x)-f(x_0)|<\varepsilon\;.
The difference is, that I noted that ##\delta=\delta(x_0,\varepsilon)## depends on location ##x_0## as well as on the margin ##\varepsilon.## We only say ##x\to f(x)## is continuous without mentioning the location if ##f## is continuous for all ##x_0## in the domain of ##f.## But ##\delta## may depend on the various locations ##x_0.##
A third definition is uniform continuity. It simply expresses the fact that we can chose ##\delta = \delta(\varepsilon) ## without using the location ##x_0.## We have
\forall\;\varepsilon>0 \;\;\exists \;\delta(\varepsilon) \, : \, |x-x_0|<\delta(\varepsilon) \Longrightarrow |f(x)-f(x_0)|<\varepsilon\;.
for any two ##x,x_0## in the domain of ##f.##
The question in the exercise is thus: Can ##\delta## be chosen independently from the location ##x_0##? Can we choose ##\delta=\delta(\varepsilon)## only depending on our choice of the margin ##\varepsilon## anywhere in the domain or not?
The typical example is ##f(x)=\dfrac{1}{x}## on ##(0,1].## It is continuous but not uniformly continuous because our ##\delta## would be
\delta=\delta(x_0,\varepsilon)= \min\left\{\dfrac{x_0}{2}\, , \,\dfrac{x_0^2\varepsilon}{2}\right\}
as
$$\left|f(x)-f(x_0)\right|=\left|\dfrac{1}{x}-\dfrac{1}{x_0}\right|=\left|\dfrac{x-x_0}{xx_0}\right|\leq \dfrac{2\left|x-x_0\right|}{x_0^2}<\dfrac{2\delta}{x_0^2}<\varepsilon\;.$$
Reply
The problem asks you to discuss those functions, not necessarily to mathematically prove what you discuss. Can you recognize an uniformly continuous function when you see its graph? Here are the three functions.
Discuss. :-)
Reply
I actually wanted mathematical proof . That was the intention of the problem .
Proofs don't appear out of thin air. You need to look at the functions in this case and decide why they are or are not uniformly continuous. Then, the proof is a matter of mathematical technique in turning an idea into a formal epsilon-delta argument.
To determine uniform continuity, what sort of thing are you looking for in a function? This is the other side of mathematics: taking a formal definition and understanding what sort of behaviour it is defining or encapsulating.
Post #4 is a great start to solving this problem.
Reply
Then you should go one step back in $$|x-y|<\delta\implies |\tan x-\tan y|=\frac{|\sin(x-y)|}{|\cos x\cos y|}\leq \frac{1}{|\cos x\cos y|}$$ and rather look for what pushes ##\frac{|\sin(x-y)|}{|\cos x\cos y|}## from below.
intuitively , i get that it shouldn't be uniformly continuous as the denominator tends to ##0## as ##x,y## tends to ##\frac{\pi}{2}## making it unbounded . But how do i prove it with rigor?
Are you able to state the condition/definition that a function is not uniformly continuous?
The first step is to state what you are trying to prove.
PS This is not as easy as you might think! You have to negate the condition for uniform continuity.
Reply
The function is obviously continuous in its domain. Assuming it was uniformly continuous means that there is a ##\delta(\varepsilon)## such that ##|\tan(x)-\tan(y)|<\varepsilon## whenever ##|x-y|<\delta(\varepsilon).##
You have to show that ##\delta(\varepsilon)## cannot be chosen independently from ##y## as ##y## approaches ##\pi/2.## Take a value ##\delta(\varepsilon)## that does not depend on ##y## and find a contradiction by choosing two different values ##y## close to ##\pi/2,## one that satisfies the condition and one that does not.
Look at my example ##x \longmapsto 1/x## in post #3. It becomes quite evident if you use the series expansion of ##\tan x.##
You can make $$\frac{|\sin(x-y)|}{|\cos x\cos y|}>\frac{const.}{|\cos x|}$$.
That is not enough. You could also say that about the second function, ##\frac {\sin^2(x)}{x}##, but it is different.
That depends on what class you are in. Have you had calculus? Look at the slope or the derivative definitions. Do you know the relationship between uniform continuity and the slope or derivative?
I wrote a basic hint because it seemed like you were trying to prove the wrong thing in your work.
Are you sure they expect a rigorous proof? Did they say "discuss" or "prove"? Proofs can get hard, even for simple functions.
I still think that your first step should be to say what you think the answer is for each function and why. You should talk about the slope or derivative.
No it wasn't if your problem statement means anything. Emphasis added.
Reply
I am unsure about the epsilon delta . The only thing i could think of was consider two sequences in ##(0,\frac{\pi}{2}) : x_n=\frac{\pi}{2}-\frac{1}{n}, y_n=\frac{\pi}{2}-\frac{1}{n+1}##
Observing that ##\mid x_n-y_n\mid\to 0## and ##\mid f(x_n)-f(y_n)\mid = \mid\cot\frac{1}{n}-\cot\frac{1}{n+1}\mid## is of the form ##\infty-\infty## which can get arbitrarily large . But unsure if this is alright
source: elementary analysis by Ross
PeroK said:
Exercise 19.4:
Prove that if ##f## is uniformly continuous on a bounded set ##S##, then ##f## is a bounded function on ##S##.
That's the key to it!
I'm not sure that it will apply on the unbounded domains in the problem.
Bling Fizikst said:
I am unsure about the epsilon delta . The only thing i could think of was consider two sequences in ##(0,\frac{\pi}{2})## : ##x_n=\frac{\pi}{2}-\frac{1}{n}## ##y_n=\frac{\pi}{2}-\frac{1}{n+1}##
That is a good try. A couple of comments:
1) First, you should state whether you are trying to prove or disprove that it is uniformly continuous.
2) I had to edit your Latex to read your post.
Now for the question of ##\tan(x), x \in [0, \frac{\pi}{2})##. To prove it is not uniformly continuous, consider ##x_n = \tan^{-1}(10^n)## where ## x_n \in [0, \frac{\pi}{2})##. Clearly, ##x_n## is a Cauchy sequence (it is monotonically increasing and bounded) but ##\tan(x_n)=10^n## is not a Cauchy sequence.
EDIT: (See Theorem 19.4 and Example 6 of Ross, Elementary Analysis)
To show that ##f(x)## is not uniformly continuous, you show that for some ##\epsilon## and any ##\delta## there exist such ##x## and ##y## with ##|x-y| \lt \delta## that ##|f(x)-f(y)| \gt \epsilon##.
It's sometimes useful to note that this is equivalent to finding sequences ##x_n## and ##y_n## with the property that, for some (fixed) ##\epsilon##:
$$|x_n - y_n| < \frac 1 n, \ \text{and} \ |f(x_n) - f(y_n)| > \epsilon$$
fresh_42 said:
I think continuity is sufficient. Cauchy sequences converge to a real number ##x_0## and continuity is a local phenomenon, too. Uniform continuity is a global property.
Try ##\frac{1}{x-\sqrt 2}## on ##\mathbb Q##.
We are not in ##\mathbb{Q}.## And what does ##\sqrt{2}## even mean in ##\mathbb{Q}##, or continuity? We have real numbers in the domains and limits available. Hence
\begin{align*}
|f(x_n)-f(x_m)|&=|f(x_n)-f(x_0)+f(x_0)-f(x_m)|\\
&\leq \underbrace{|f(x_n)-f(x_0)|}_{<\varepsilon/2}+\underbrace{|f(x_0)-f(x_m)|}_{<\varepsilon/2}< \varepsilon
\end{align*}
for all ##|x_m-x_0|,|x_n-x_0|<\delta(x_0,\varepsilon)## and sufficiently large ##n,m\in \mathbb{N}.##
Continuity is equivalent to ##\displaystyle{ \lim_{n \to \infty}f(x_n)=f(\lim_{n \to \infty}x_n)}.##
fresh_42 said:
We are not in ##\mathbb{Q}.## And what does ##\sqrt{2}## even mean in ##\mathbb{Q}##? We have real numbers in the domains and limits available. Hence
\begin{align*}
\end{align*}
When you restrict to Rationals and consider a sequence that should converge to ##\sqrt 2##, the image of the sequence will blow up.
Good point, but not when the domain is an open set. Several of the examples in the OP are on open sets with a singularity at an open end of the domain.
fresh_42 said:
How do you define continuity on ##\mathbb{Q}##? If you have a location with a discontinuity, then uniformity won't save you.
It's standard definition for a metric space. At any rate, just use the map ##f(x)=1/x##, from ##(0,1)\rightarrow \mathbb R## and consider the Cauchy sequence ##\{1/n \} ## in ##(0,1)##. It's mapped into the non-Cauchy sequence ##\{1,2,3 ...\}##.
Reply
1) a uniformly continuous function is bounded on a bounded domain.
2) a function whose derivative is bounded on an interval is also Lipschitz continuous on that interval, hence also uniformly continuous.
that does it for all parts. (note that a restriction of a uniformly continuous function from an infinite interval to a finite subinterval is still uniformly continuous.)
