Uniform convergence ( understanding how to apply a theorem)
11 replies · 6K views · last reply
bennyska
show a function f_n is not uniformly convergent using a theorem:
if f_n converges uniformly to F on D and if each f_n is cont. on D, then F is cont. on D
not really sure what to do. use the contrapositive? would that be, then, if F is not continuous on D, then either f_n is not uniformly convergent on D or each f_n is not cont. on D? specifically, the function is f_n=e-nx. i think if i understand how to apply the theorem, it shouldn't be too hard.
Well, for [tex]f_n(x)=e^{-nx}[/tex], you should first find the pointswize limit (this will be the uniform limit if the convergence were to be uniform). Is the pointswize limit continuous??
i'm still having a little trouble understanding the difference between pointwise and uniform convergence (although this problem may have helped me understand it).
my domain is [0, infinity). if x=0, then the function converges pointwise to F(x)=1. if i fix x in (0,infinity), then it converges to F(x)=0. so F(x) is not continuous?
when i asked someone else this (original) question, the reply i got was, "to restate the theorem, if a sequence of continuous functions converges to a discontinuous function, then it does not converge uniformly."
so, if i understand this concept, for uniform, no matter what x i choose, it converges to the same function, where as for pointwise, the function it converges to depends on how i fix my x.
Yes, that's basically it. If the convergence were uniform, then the limit would be continuous. But it isn't, so the convergence is only pointswize.
Hmm, I don't really understand what you said, but I don't think that's what uniform convergence means.
Pointswize convergence is very easy, just calculate the limit for any x. The limit of other x-values don't matter for pointswize convergence.
Uniform convergence is stronger than pointswize convergence. Meaning: the other x-values will matter!
In pointswize convergence, you only want fn(x) to be very close to f(x). For other x-values, it may happen that fn(x) is very far from f(x).
But uniform convergence demands that fn(x) is very close to f(x) AND it will demand that for other x-values it occurs that fn(x) is as close to f(x).
HINT: download the free program on www.padowan.dk/ You can use this to simulate convergence of functions:
- First type Ctrl+F and add n and 1 to the list.
- Then type Ins and add a function to your choice, for example e^(-n*x)
- Then go to Calculate -> Animate (or something like that), and you can view an animation of the convergence of functions.
Try to view the convergence of several sequences of functions and try to get a feeling for uniform/pointswize convergence. Try the following functions:
[tex]e^{-nx},~x^n,~\sin^n(x),~\frac{1}{n}\sin(nx)[/tex]
this should give you a feeling of uniform convergence...
i'm having a hard time doing latex on this board, so i'll just sum up what i did like this.
my domain is [0, infinity). i showed if x=0, then fn(x) converges to 1, and if x is in (0, infinity), then fn(x) converges to 0. so my F, defined one way when x=0 and another when x>0, is not continuous. then the theorem says that fn does not converge uniformly. (a latex pdf is attached)
Yes, that is correct. However, in your pdf, you should write [tex][0,\infty)[/tex] and not [tex][0,\infty][/tex]...
To use LaTeX here, just put your statements inside [ tex ] ... [ /tex ] (without spaces), instead of $ ... $
( t being epsilon-close to c means that | t - c | < epsilon , after fixing some arbitrary epsilon [ this is an example on R ] )
( t being in a delta -neighbourhood of c means that after fixing some delta, 0 < | t - c | < delta [on R again ] )
Uniform convergence is about this: given functions f_n on some domain A, you have a different sequence for each input x; this is clear because evaluating each function at x just gives you a number and thus you get a sequence of all outputs of f_n at some x. So to be clear, to have a sequence of functions f_n, you will have many more sequences f_n( c ) after evaluating each function at c ( where c is something in your domain A, i.e. a different sequence f_n( c_k ) for different c_k's ). When your functions f_n converge uniformly on A, it means that every one of these many sequences f_n( c ) [ for some arbitrary c ] converge to their limit "at the same time" ( i.e. for the same N, each n > N are epsilon-close to their respective limits ). To think about this, imagine the sequences were not going to infinity, but rather, they were going to some point a. Then, a "uniform convergence" of the sequences f_n( x_i ) means that every sequence f_n ( x_i ) for each x_i , get epsilon-close to their respective limits, as long as n is in some delta-neighbourhood around n ( any n in this delta-neighbourhood of a should allow f_n( x_k ) to be epsilon-close to its respective limit L ).
To be clear: It might not be the case that you will be able to find some nice non-piecewisely defined function such that a sequence of functions f_n ( x ) converges to it for all x; but that is okay. The "f(x) " represents an individual limit of a sequence of numbers f_n( x ) after fixing x. A function f may be defined encompassing every limit of the sequences f_n ( x ) ; since each f_n is a function, we have well-definedness of such a function f, since the same x for every f_n will not produce different values.
The continuity of a limiting function f given that each f_n is continuous and converge uniformly to f is a result of this theorem:
suppose "f_n converges uniformly to f" on some domain A. Furthermore, for each f_n,
lim x -> t f_n ( x) exists. Then, lim x -> t f(x ) exists, and
lim x -> t ( lim n-> infinity f_n ( x ) ) = lim n -> infinity ( lim x -> t f_n ( x ) )
In the case of each f_n being continuous, we get that f is continuous:
lim n -> infinity ( lim x -> t f_n ( x ) ) = lim n -> infinity f_n ( t ) = f( t ) = lim x -> t ( lim n-> infinity f_n ( x ) ) = lim x -> t f ( x ) which shows that f is continuous.
thanks for your help. it will take me a few reads to understand that last post.
you're welcome, I edited it though to clear something up: you have to make sure that uniform convergence is ultimately dependent on the particular domain for which the property holds; so each sequence f_n ( x ) converges "at the same time", given that each x is in a domain A.
Also, since you were asking, I would like to add something. The difference between point-wise convergence and uniform convergence is this: point-wise convergence is a property of a single sequence f_n(c ) after being given a c. Uniform convergence is a "collective property" of an entire interval [a,b] or domain A. That is, a point-wise convergence just tells you that if you have functions f_n, and each f_n is defined at some c, so evaluating each f_n at c gives you a sequence of numbers f_n( c ). If f_n is pointwise convergent at c, then the sequence of numbers f_n(c) converges. Uniform convergence means that an entire domain A does whatever I said it would do in my previous post. ( So "uniform convergence" of a single point is pretty much meaningless, it is reduced to mean the same thing as pointwise convergence of some point )
Pointswise convergence is also a "collective property". I can easily say that [tex]f_n(x)=x/n[/tex] converges pointswise to 0 on the interval [0,1].
you are right, but I think that you can still look at that as an "individual" property, since to say
f_n ( x ) = x/n converges pointwise to 0 on [a,b] requires each x in [a,b ] to individually pointwise convergence , a criterion that doesn't rely on the pointwise convergence of anything else in the interval. So pointwise convergence can be a "collective property" as a collection of things that satisfy an individual property. At any rate, the uniform convergence criterion requires knowledge of the convergence of other sequences f_n( c ) for c in the same domain, whereas the criterion for pointwise convergence requires no such knowledge
