Unit tangent vector vs principal normal vector
85 replies · 11K views
[in reply to #29 which was edited afterwards] :
No, I did NOT ask you to differentiate ##
\ \vec N\cdot \vec T^2 \ ##, I asked: what gives ##
\ \vec N\cdot \vec T \ ## when it is differentiated wrt time.
Then I asked you what the time derivative of ##\vec T^2## is. After a while we came to ##2\;\vec T\cdot\vec T'##
(I know, you used the shorthand 2TT' that is used by very experienced folks, but I like to take small steps and stick to the explicit vector notation :smile: -- just checking: you do understand that indeed $$ {d\vec T^2\over dt\ }= 2\; \vec T\cdot {d\vec T \over dt}\quad\quad\quad? \quad ) $$​
In that case we put 1 and 1 together, connect the dots, have our Aha ! moment and see that $$ {d\vec T^2\over dt } \propto \ \vec N\cdot \vec T \ ! $$
chetzread said:
do you mean ##\vec N \cdot \vec T \ = 0\ ##? but , I am shown that N = 1 , i am still not convinced that N.T = 0 ...
Quick succession of posts - delay on the line causes crossings.
Yes, we are working towards ##\vec N\cdot \vec T \ = 0 ##
No, we have not shown that ##\vec N = 1## (can't be that a general vector is equal to a number). We have shown that ##\ \|\vec N\| = 1 \ ##.
deleted
ok , i can understand that ...but , i still can't understand why N.T = 0 ?
we only reach this
$$ {d\vec T^2\over dt } \propto \ \vec N\cdot \vec T \ ! $$ , but still haven't reach N.T = 0 ? do i left out something ?
Ah, again postings cross. We go faster now ! Good. This is still in reply to #33:
chetzread said:
Can you explain further?
Yes.
Do you remember ##\vec N \equiv \displaystyle { \vec T'\over \|\vec T'\|} ## ?
And do you remember ## \|\vec T\| = 1## , so that ##\vec T\cdot\vec T = 1 \ ## ?
and
{d\vec T^2\over dt\ }= 2\; \vec T\cdot {d\vec T \over dt}\quad\quad\quad? \quad $$
so that - using ##\displaystyle{d\over dt }\; 1 = 0 \ ## we come to the unavoidable conclusion that
[and now we smoothly go into responding to #34] :
0 = {d\over dt }\; 1 = {d\over dt }\; \vec T^2 = 2 \vec T \cdot {d\over dt }\vec T = 2 \;\vec T\cdot\vec N \; \|\vec T'\| \quad \Rightarrow \vec N \cdot\vec T = 0 $$
(because | T| = 1 ≠ 0 ).
[edit] Oops, sorry, ##\ \|\vec T'\|\ ##, not ##\ \|\vec T\|\ ## without the quote. But if ##\ \|\vec T'\|\ = 0 ## then ##\ \vec N = 0 \ ## too.
BvU said:
Ah, again postings cross. We go faster now ! Good. This is still in reply to #33:Yes.
and
it should be 2T (dott) N = 0 , am i right ? why there's an extra || T || ?
##\vec N \equiv \displaystyle { \vec T'\over \|\vec T'\|} \Rightarrow \vec T' = \vec N\; \|\vec T' \| \ ##.
Before I forget: you can read all about this in Paul1 , Paul2 , Paul3 (I do find the pdf downloads easier on the eyes). And you see that it's at the end of very thick books; no wonder it takes us a while :smile:
in post #35 , do you mean ##\ \|\vec T'\|\ = 0 ## , so that
{d\vec T^2\over dt\ } $$ = 0 ?
No, it's the other way around: ##\displaystyle {d\vec T^2\over dt\ } = 0 ## always, because ##\vec T^2 = 1##.
We had $$\vec N \equiv \displaystyle { \vec T'\over \|\vec T'\|} \Rightarrow \vec T' = \vec N\; \|\vec T' \| \ $$ with the complication that, if ##\ \|\vec T'\|\ =0## then ##\ \vec N\ ## does not exist. (actually, it's the same complication as with ##\ \vec T\ ## when ## \ \vec v' = \vec 0\ ##).
From ##\|\vec T\| = 1 \ ## we deduce ##\ \vec T\cdot \vec T' = 0 \ ##. Therefore ##\ \vec T \cdot \vec N \; \|T'\| \;= 0\ ## but that's not the same as showing that ##\ \vec T \cdot \vec N = 0\ ## which we needed to prove that ##\ \vec T \perp \vec N\ ##.
For that last step, from ##\ \vec T \cdot \vec N \; \|T'\| \;= 0\ ## to ##\ \vec T \cdot \vec N = 0\ ##we need ## \ \|T'\| \;\ne 0\ ##, so I looked at that separately.
I'd like to summarize this with the simplest possible example: uniform circular motion in 2D.
So: ##(x,y) = (\cos\omega t , \sin\omega t)## in cartesian coordinates.
What are ##\ \vec v##, ##\ \vec T## and ##\ \vec N## ?​
if we need to show that ##\ \vec T \cdot \vec N = 0\ ## , then , we need ||T'|| = 1 , am i right ?
So that we can ignore the ||T'|| in ##\ \vec T \cdot \vec N \; \|T'\| \;= 0\ ## , to get ##\ \vec T \cdot \vec N \= 0\ ##
BvU said:
No, we only need ##\ \|T'\| \;\ne 0\ ## (fortunately).
so , we are ignoring the value of ##\ \|T'\| \ ## to get T (dot)N only , rather than ##\ \vec T \cdot \vec N \; \|T'\| \;= 0\ ## ?
BvU said:
We are not ignoring it: we divide left and right by it. That can only be done if it's not zero -- hence the caution.
can you explain further ? i still couldn't gt it
$$ \vec T \cdot\vec T' = 0 \quad \Rightarrow \quad A \; \vec T \cdot\vec T' = 0 $$ for any ##A##.
Multiply left and right with ## A = 1/\|\vec T'\| ## to get $$\quad\quad \Rightarrow \vec T \cdot\vec N = 0 $$
ok , since anything including ## A = 1/\|\vec T'\| ## multiply by 0 = 0 ?
we multiply RHS of ]$$ \vec T \cdot\vec T' = 0$$ by 0 will get 0 ...
my working is in 317.jpg[/QUOTE]
chetzread said:
Can someone explain how to turn the formula of curvature T'(t) / r'(t) into | r'(t) x r"(t) | / | (r't)^3 | ?my working is in 317.jpg
Well, can someone help to explain which part gone wrong now?
We'll come to that. The example from post #40 can even help us there:
i am not sure what does ##\ \vec v## mean ? do you mean ##\ \vec v = r\cos\omega t , r\sin\omega t##
No. Given is: ##\vec r(t) = (x(t),y(t)) = (\cos \omega t, \sin \omega t) ##.
What is ##\vec v(t) \equiv \;\displaystyle {d\vec r(t)\over dt} ## ?
Have you never done such things before ?
here it is .
Good thing I asked. In your ##\vec v## I can still distinguish an ##\hat\imath## and a ##\hat\jmath##, so they can pass as vectors. An alternative notation would be ##\vec v(t) = (-\omega\sin\omega t, \omega\cos\omega t)\ ##.
I'm not sure what you mean with ##V##, but if it's ##\vec r'(t)\over \|\vec r'(t)\| \ ##, then so far we have used the name ##\vec T##. Why not keep that name ? And: it is a vector, not a number !
V is not r'(t) ?what is V now? I'm confused...
How can you be confused about something you introduced yourself ? line 2 in your post has a ##v## (small v) but you mean a vector. Learn yourself to clearly designate vectors as vectors and scalars as scalars.
Line 3 has a ##V## big V (right ?) what do you mean with that ?
they should be the same v , by the way, what is ##v## ? i am still blurred.
v is r'(t ) ?
then v is same as T ?
v is r'(t ) ?
v is r'(t ) ?
v is r'(t ) ?
