Unit tangent vector vs principal normal vector
85 replies · 12K views · last reply
chetzread said:
by the way, what is ##v##
As I said, learn yourself to clearly designate vectors as vectors and scalars as scalars.
There are a few possibilities for the notation.
The one in your textbook is
  • vectors are bold
  • vector norms are written with double vertical lines (##\ \|\ ##)
and is not very suitable for handwriting. If your class doesn't have it's own standards, I would advise:
  • vectors are written with an arrow above (##\ \vec r\ ##)
  • a single | is enough for a norm (##\ |\vec r| \ ## )
Once you are more experienced you can make it easier by dropping the | : ##\vec r## is the vector, ##r## is the norm. Not now, later.
Stay with your standard. Use it consistently.
You are going too fast without a drivers license. Re-post #57 with a decent notation.
In answer to your #56: what is ##v## :
It is common to designate a position vector as ##\vec r##.
In Cartesian coordinates a 2D ##\ \ \vec r = (x,y) \ ## and a 3D ##\ \ \vec r = (x,y,z)##.
x and y may depend on time and you get e.g. ##\ \ \vec r(t) = (x(t),y(t)) \ ##
The time derivative is the velocity vector, commonly designated as ##\vec v##. So ##\vec v = \displaystyle d\vec r\over dt ##.
In Cartesian coordinates a 2D ##\ \ \vec v = (v_x,v_y) = \left (\displaystyle {dx(t) \over dt}, \displaystyle {dy(t) \over dt} \right) \ ##,
often abbreviated with a quote for ##{d\over dt}##. E.g. a 3D ##\ \ \vec v = (x',y',z')##.
The time derivative of the velocity vector is the acceleration vector, commonly designated as ##\vec a##. So ##\vec a = \displaystyle {d\vec v\over dt} ##.
In Cartesian coordinates a 2D ##\vec a = (a_x,a_y) = (x'', y'') ##
I could retype all 385 pages of Paul's excellent pdf, but I suggest you read through it on your own -- just to get familiar. And make a lot of exercises to build up experience.
I spent quite some time typing #61. #63 is identical to post #1 in the thread that was merged into this one. It looks as if you don't want to learn the language of simple vectors and vector calculus, so: yes I can but you wouldn't understand. Is there a good reason for that ?
Ok, here is after correction
So far
we have ##\vec r\qquad##
don't forget the arrow over the ##r## -- or some other way to clearly mark it as a vector
don't forget the brackets
##\qquad \vec r(t) = (cos\omega t,\sin\omega t)\ \ ## which was the given data.​
we have ##\vec r'\qquad ## which is ##\vec v## (so ##\vec v## is NOT your ## {r'\over|r'|} ## !)
don't forget the arrow over the ##r'## -- or some other way to clearly mark it as a vector
##\qquad \vec r'(t) = (- \omega \sin\omega t,\omega\cos\omega t)\ \ = \omega (\sin\omega t,\cos\omega t)\ \ ## .​
We see that ##|\vec r| = 1 ## (right ?) and we see that ##|\vec r'| = |\omega| ## (right ?)
But then you go all wrong by thinking that ##\vec T## is not a vector.
And what you do to find ##\vec N## is a mystery to me. Again, you write it as a number, which it is NOT. ##\vec N## is a vector !
BvU said:
But then you go all wrong by thinking that ⃗T\vec T is not a vector.
And what you do to find ⃗N\vec N is a mystery to me. Again, you write it as a number, which it is NOT. ⃗N\vec N is a vector !
sorry , for T , it should be (-w sin wt i + w coswt j ) / w
, similarly ,
for N , it should be = (-(w^2)((coswt)^2) i - (w^2)((sinwt)^2) j ) / (w^2)
Again , here's the formula have in my book
BvU said:
Do you know how to calculate the norm of a vector product such as ##\ \vec r'\times \vec r'' \ ##?
do you mean express it in form of unit vector ?
why not answer a question with an answer instead of with a question :smile: ?
To your question: No. Unit vectors are boring :smile: : they have norm 1.
In this case you are (of course :rolleyes:) not interested in the vector itself (*), but in the length of that vector product. That is ##\kappa##, a number.
(*) but you can ask yourself which way it is pointing, e.g. for a particle in a circular trajectory in the plane...
, similarly ,
Yes, so you have ##\vec T = \omega(-\sin \omega t,\cos\omega t)## and ##\vec N = -\omega^2 \vec r\ .\ \ ## Easier on the eyes...:rolleyes:
[edit] Oops! it's even simpler. See #77 for a corrected version...
------------------------------------And no need to repeat the formula in your book, that way we will end up with > 100 posts and many many pages ...o_O
No, I mean do you know the something in $$|\vec r'\times\vec r''| = |\vec r'| \;|\vec r''|\; \text{something} $$
well, here's my working...I didnt get the same ans though, which part of working is wrong?
i get w and 1 respectively when i used different approach...
If you recognize ##\vec r = (cos\omega t, \sin\omega t) ## as describing the unit circle, you know which of the answers for ##\kappa = {1\over \rho}## is wrong ...
Check your own post #66...
And cry out that I made two huge mistakes in post #72 o:) o:) o:) -- sorry about that !
i still couldn't figure out which part is wrong, can you point out?
A unit circle has a radius 1, so my guess is that the answer 1 is correct and the answer ##|\vec \omega|## is wrong. And I've found why and it's somewhat my fault because in post #72 I made two huge mistakes.
Note that we are doing two things in parallel: working out the simple example ##\vec r = (cos\omega t, \sin\omega t)## and make an inroad for your long-standing question as in post #1, #13 and #63.
I humbly fix #72:
So far we have the unit vectors (:smile:) ##\ \ \vec T = (-\sin \omega t,\cos\omega t)\ \ ## and ##\ \ \vec N = -\vec r\ \ ## Curvature is 1 and radius is 1.
In the more general case the acceleration was decomposed into a tangential component by means of projection . You did not have a problem with that step ? Because we are going to use that to understand the magnitude of the normal component "The second equalities will be left as exercises"
I humbly fix #72:
component
You mean k=(T't) /(r't) is wrong?
I don't know how to divide a vector by a vector. (or perhaps I intentionally misunderstand your notation :smile: )
Anyway, yes: that ##\kappa\equiv \displaystyle {|\vec T'|\over |\vec r'|} ## evaluates to ##|\omega|/ |\omega| = 1 ##.
Anyway, yes: that ##\kappa\equiv \displaystyle {|\vec T'|\over |\vec r'|} ## evaluates to ##|\omega|/ |omega| = 1 ##.
T'(t) = (omega ^2) , right?
No, not if ##\ \ \vec T = (-\sin \omega t,\cos\omega t)\ \ ##...
And:
Please please please become adept at using a sensible and consistent notation. ##\vec T'## is a vector. ##\omega^2## is a number. They can never never never be equal.
And:
##\ \ \vec T = (-w\sin \omega t, w\cos\omega t)\ \ ##...
##\ \ \vec T' = (-(w^2)\cos \omega t, (w^2)\sin\omega t)\ \ ##...
why you left out w for ##\ vec T\ ##...
Here's my previous working
In your working (I had seen it and checked it already) in the expression for ##\vec T## you can divide out the ##\omega## in the numerator against the ##\omega## in the denominator. (That way you also get a vector that clearly has length 1). Differentiate wrt time to get ##\vec T' = -\omega \;(\cos\omega t, \sin\omega t)## ...
The expression for ##\vec T## in your working may be right (apart from the incorrect notation), but
you should still correct your expression for ##\vec N##: it is not correct.
do you mean by cancelling off the w in the denominator and numerator ##\vec T##
and cancelling off (w^2) in the denominator and numerator ##\vec T'##
eventually, we get magnitude of ##\vec T## and ##\vec T'## equal to 1? k =1 ?
tat's weird, how can we do that?
yes
No. You differentiate wrt time . See post #83.
Yes for ##|\vec T|##, beccause ##\vec T## is a unit vector.
No for ##|\vec T'|## because ##\vec T'## is NOT a unit vector. (but of course ##\vec N \equiv \vec T'/|\vec T'|## IS a unit vector !)
see the example. Very useful example !​
Because ##\omega## is a scalar. Not to be confused with possible vectors ##\vec \omega##.
In case you insist on a vector ##\vec \omega## in the example: there you have ##\vec \omega = (0,0, \omega)## pointing in the z direction. In short, with the scalar ##\omega##, the norm of ##\vec \omega ## is meant.) I agree that one can become confused, especially when sloppy or inconsistent with notation in general :rolleyes: .​
