Unreliability of Hafele & Keating Experiment: A Critical Analysis
Yehuda
Does someone have any opinion regarding the following paper attending to prove that Hafele & Keating experiment (that actually verified the time distorsion caused by speed & gravitation in General relativity) to be highly unreliable?
Hafele & Keating Tests; Did They Prove Anything?
A. G. Kelly PhD*
http://www.dipmat.unipg.it/~bartocci/H&KPaper.htm
The paper is an allegation of academic fraud - such things do not belong in a scientific paper, and I'm loathe to accept the allegation without any real evidence.
Regardless, better experiments have been performed since then, so if you're looking for a way to disprove Relativity, you haven't found it.
I aggree with you that this article looks quite suspicious but this is more a feeling than actual data. I would like to ask some expert.
I will move this dicussion to the "special Relativity Forum".
Thanks
I forget the other papers, but there are other sources that discredit the HK.
Here's one By Louis Essen (the inventor of the atomic clock) that said the experiment was not nearly accurate enough...
L Essen, Electron. Wireless World 94 (1988) 238.
HK isn't really a concern anymore with the advent of GPS. GPS is far more accurate. If you're just looking into finding controversy, begin examining the GPS calculation adjustments made in jet airplanes. Accuracy there requires c+/-v calculations but I believe the mainstream explanation for this is simply the one-way sagnac effect.
Basically, the dissenter opinion is that to be accurate, jet airplanes must calculate the distance toward a sattellite they have traversed from the time the signal was transmitted to when it was received. They then subtract this distance. (this is actually true) By doing this, the end calculation of c is c+v.
On the other hand, this same apparent c+v happens in a sagnac device and the GPS satellites have proven to act in the same way as a sagnac ring such that the travel time of C in one direction around the Earth is faster than the other (simply a shorter distance) So the apparent problem with GPS on airplanes is just another example of the Sagnac effect already described by GR.
Either way, it makes for fun discussion. (and regardless of my beliefs, devil's advocate can be loads of fun)
Could someone correct me on the two opinions if I'm wrong...
Here's a paper about observations of relativistic time effects on a clock in an airplane flying around in circles:
http://tycho.usno.navy.mil/ptti/ptti2002/paper20.pdf
There is a giant tempest in a teapot going on about relativity in rotating frames - both on the net and in the professional physics community.
One can, for instance, spend about $200 to get the following book devoted exclusively to this topic an this topic alone.
But there isn't really any serious difference in the results of the calculations, it appears to be mainly a giant philosophical muddle. When push comes to shove, one can (for instance) simply adopt a non-rotating frame of reference (such as the Earth-centered inertial frame used for GPS) and do one's calculations in this non-rotating reference frame. General covariance insures that the choice of the frame of reference is irrelevant. Everyone agrees that this gives the right results, but there appears to be an unnecessary amount of controversy over how to go about formulating the problem in an inertial frame.
My personal favorite paper on the topic is by Tartaglia, I'll cut and paste a link to the paper I like when I get back to my other computer.
[add]
Tartaglia et al
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
