Use Newton's second law to find the net force acting on both blocks
The problem involves two blocks connected by a massless string, with one block on a surface and the other hanging. The context includes applying Newton's second law to determine the net force acting on both blocks and to calculate the speed after moving a specified distance, considering kinetic friction.
  • Participants discuss the application of Newton's second law and the role of friction in the calculations. Questions arise regarding the interpretation of the problem setup and the forces acting on each block.
Some participants have provided guidance on considering the force of friction and its impact on the calculations. There is an ongoing exploration of the assumptions made in the problem, particularly regarding the forces acting on the blocks.
Participants note the importance of accurately incorporating the coefficient of friction and clarify the setup of the problem, including the positioning of the blocks and the forces involved.
Zhalfirin88
Two blocks with masses m1 = 1.10 kg and m2 = 3.20 kg are connected by a massless string. They are released from rest. The coefficient of kinetic friction between the upper block and the surface is 0.490. Assume that the pulley has a negligible mass and is frictionless, and calculate the speed of the blocks after they have moved a distance 47.0 cm.
Hint: Use Newton's second law to find the net force acting on both blocks. Since they are connected by a string, they act as one body and have the same acceleration.
So I did that, but ended up wrong.
[tex]\Sigma F = ma[/tex]
[tex]-f_k + mg = ma[/tex] Because the tension forces would cancel.
[tex]\frac{-(1.1kg * 9.8\frac{m}{s^2}) + (3.20kg * 9.8\frac{m}{s^2})}{(1.1kg + 3.2kg)}[/tex]
[tex]a = 4.786 \frac{m}{s^2}[/tex]
[tex]v_f^2 = v_o^2 + 2a\Delta x[/tex]
[tex]v_f = \sqrt{2 * 4.786\frac{m}{s^2} * .47m}[/tex]
[tex]v_f = 2.12 \frac{m}{s}[/tex]
But this was wrong, so where did I go wrong?
It looks like you had friction in your equation (-fk) but did nothing with it. I think you calculated the velocity of the blocks without any friction.
To be honest, I don't really understand the problem. What does it mean by 'between the upper block and the surface'?
Well we had a picture, and I don't know how to transfer it over. Basically m1 is on a surface with a string attached to m2. m2 isn't on a surface. The only forces acting on m2 are mg pulling it down and the tension pulling it up.
Think of a cliff, where m1 is on the cliff and m2 is not on the cliff.
Edit: Aha! found a picture
http://spiff.rit.edu/classes/phys311/workshops/w5b/level_atwood/cart_and_weight.gif
Yeah, that was my assumption. = ), just wanted to be clear, especially that the upper block=m1.
Try finding the force of friction applied to m1.
Fk=uk*FN
This is the force applied opposite to the direction of m1's motion.
[tex] \frac{-(1.1kg * 9.8\frac{m}{s^2} * .49) + (3.20kg * 9.8\frac{m}{s^2})}{(1.1kg + 3.2kg)} [/tex]
[tex] a = 6.065 \frac{m}{s^2} [/tex]
[tex] v_f^2 = v_o^2 + 2a\Delta x [/tex] [tex] v_f = \sqrt{2 * 6.065\frac{m}{s^2} * .47m} [/tex]
[tex]v_f = 2.388 \frac{m}{s}[/tex] And that was correct! Just forgot to multiply by the coefficient of friction, thanks!
