hxtasy
- 112
- 1
Hello,
I am playing with fan placement on a computer i am building and i am currently calculating (with solid works flow simulation) how the fans will cool the processor heat sink.
I'm not really a theory type of guy, i like to test real world. Basically what i want to do is simulate the microprocessor's heat without having to attach a real motherboard and over heat the motherboard.
I'm thinking i can take some high power resistors, and attach them to the bottom of the same heat sink i am using for the processor. I will use with LabVIEW and a data acquisition board (because that's what i have laying around) and i will just run a current through the resistor until it heats the heat sink up to the temperature i want, then kind of do a pulse width current with some hysteresis to keep the heat steady. If i get this working i can then vary the fan placement and take note on what it does to the heat sink's temperature.
The problem is, i have a higher power processor (70-95 watts normal not over clocked) and i am assuming i want the resistor to attach to the heat sink with the same surface area as the processor would take up, about 1.4 square inch. because of this i am limited to some smaller dale type resistors, around 25 Watts (again trying to use stuff i have laying around).
So my question is, obviously if i throw more current through these smaller resistors to try to create the heat a 95 watt processor would emit, i would probably de-rate them to a higher resistance but i don't think they would blow up or anything. Do you guys have a better idea of how to heat the heat sink, like an inductive coil or something?
Is it safe to assume that 95 watts of processor power will probably need around the same wattage (roughly) of resistive power, to get similar heat quantities?
Please throw some ideas my way, crazy or pragmatic, as i am just pondering this at the moment for fun.
thanks!
-Hx
thanks!
-Hx
