Using a bifurcation diagrams and time dependent parameters
MathCreature
Hello,
I'm lost at where to go after drawing bifurcation diagram of
$$\dot{x} = r + x - x^3.$$ If we also assume our parameter is time dependent such that
$$\dot{r} = -\delta x.$$ How could we use our initial bifurcation diagram to sketch solutions for small δ?
Is there a reason why you would not want to consider the planar system
\left\{
\begin{aligned}
\dot{x} &= r + x - x^3\\
\dot{r} &= -\delta x
\end{aligned}
\right.
in a neighborhood of ##(x, r) = (0,0)## and with (time-independent) parameter ##\delta## (which I suppose is small and positive)?
Another thing to note is that for time-independent ##r## the equation for ##\dot{x}## is the cusp normal form with parameters ##\beta_1 = r## and ##\beta_2 = 1##, but although I have heard of it, I am not sufficiently familiar with "slowly time-varying parameters" to see immediately how that normal form could provide an easier approach than when we just start with the planar system.
Thanks for the reply.
I believe I found someone who has the same problem: https://math.stackexchange.com/questions/2935059/bifurcation-of-time-dependent-parameters
I've gone through my "Strogatz's Nonlinear Dynamics and Chaos" and haven't found any problems like this, so I'm at a loss at how we can qualitatively sketch solutions. If $$\delta \approx 0,$$ then our parameter is almost constant for small x, though as x→±∞ we should eventually hit the bifurcations.
I don't believe we are using the system, but I've been looking done that path just to get an intuition of what's going on.
