Using a microprocessor signal to control motor power
  • Thread starter Thread starter TheCoolBrian
    Power
5 replies · 2K views
TheCoolBrian
Help With power stuff?
ok let's say I want to power a motor and I programed a microprocessor to do so but when you send the signal from the microprocessor to the motor I know it won't be enough energy. How would I make the motor activate when it gets a signal from the microprocessor so in other words how do I use a signal from the microprocessor to complete a power connection from direct power to the motor.
Sorry I,am new and I don't know if I really explained this right
Would I use a Transistor for something like this?
http://www.arrickrobotics.com/highload.html
I'd use a PLC to send the signal to a motor controller instead.
CS
You haven't told us nearly enough information. What kind of motor is it?
- Warren
Thanks for the helps guys
As has been mentioned, you would typically use a motor controller for this task. Which type of controller depends on which type of motor, and what you need it to do. You may not even need a microcontroller/microprocessor, depending on the application. If it's a custom motor, you may need to design a corresponding custom controller.
Hopefully it's a stepper motor; those are the most fun to program, and have the neatest controllers.
