Evaluating the Limit of Cosine Function Using L'Hospital's Rule - Explained
The limit of the expression $$\lim_{x \to 0} \cos(\pi/2\cos(x))/x^2$$ is incorrectly evaluated by taking the limit of each part separately. The correct approach involves applying L'Hospital's Rule to the entire expression rather than isolating components. It is emphasized that the product rule for limits cannot be applied when one limit approaches zero and the other approaches infinity. The discussion suggests using a substitution for small values of x to simplify the evaluation. Ultimately, a thorough application of L'Hospital's Rule is necessary to find the correct limit.
navneet9431
<Moderator's note: Moved from a technical forum and thus no template.>
I tried to evaluate the limit this way,
$$\lim_{x \to 0} \cos(\pi/2\cdot1)/x^2$$ since $$\cos0=1$$
$$\lim_{x \to 0} \cos(\pi/2\cdot1)/x^2=\lim_{x \to 0} 0/x^2$$
Now apply L'Hospital's Rule twice,
$$\lim_{x \to 0} 0/2(x)=\lim_{x \to 0} 0/2=0$$
So,this way the answer is zero.
Can you please explain where am I doing wrong?
I will be thankful for help!
You cannot just take the limit for one part and leave the rest. Either you take the limit for the whole expression or not.
This would be long, but use the L'Hopital rule twice on the original expression to remove x^2 from the denominator
Likes navneet9431
It s enough to apply L'Hopital rule once. You will get a product, and arrange the factors, so they have known limits. (One factor will be sin(x)/x.)
Likes SammyS, Delta2 and navneet9431
The product rule for limits ##\lim{f(x)g(x)}=\lim{f(x)}\lim{g(x)}## holds only if both the limits of ##f(x)## and ##g(x)## are finite or ##+-\infty##. If one limit is 0 and the other is infinite, as happens in this case where ##\lim_{x\to 0}\cos(\frac{\pi}{2}\cos x)=0## and ##\lim_{x\to 0}{\frac{1}{x^2}}=\infty##, then the product rule cannot be applied.
Likes Phylosopher
If you write ##\cos x = 1- A## for small ##|x|##, your given fraction is
$$\text{fraction} = \frac{\sin(\pi/2 \: A)}{x^2}.$$ Now look at how ##A = 1 - \cos x## behaves for small ##|x|##, or use l'Hospital's rule.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
