Using Cauchy Schwartz Inequality (for Integrals)
The discussion centers on applying the Cauchy-Schwartz Inequality to a specific integral problem involving a function f(t). The user attempts to show that the integral from a to b is bounded by K²(log(b) - log(a)), using the inequality in the context of L² spaces. They set h(t) and g(t) appropriately but encounter difficulties in proving that the integral of t|f(t)|² is less than or equal to K² due to differing limits. The user expresses concern that the problem statement may be flawed, particularly when considering the behavior of f(x) as even or odd functions, which could lead to K approaching 0. The discussion highlights challenges in applying theoretical inequalities to practical scenarios.
SP90
Suppose \int_{-\infty}^{\infty}t|f(t)|dt < K
Using Cauchy-Schwartz Inequality, show that \int_{a}^{b} \leq K^{2}(log(b)-log(a))
Cauchy Schwartz: |(a,b)| \leq ||a|| \cdot ||b||
Taking CS on L^{2} gives us
(|\int_{a}^{b}h(t)g(t)dt|)^{2} \leq (\int_{a}^{b}|h(t)|^{2}dt)(\int_{a}^{b}|g(t)|^{2}dt)
Setting h(t)=\sqrt{t}|f(t)| and g(t)=\frac{1}{\sqrt{t}} we get
(\int_{a}^{b}|f(t)|dt)^{2} \leq (\int_{a}^{b}t|f(t)|^{2}dt)(\int_{a}^{b}\frac{1}{t}dt)
Obviously \int_{a}^{b}\frac{1}{t}dt is log(b)-log(a)
So we just need to show \int_{a}^{b}t|f(t)|^{2}dt \leq K^2
Obviously this is true if \int_{a}^{b}t|f(t)|^{2}dt \leq (\int_{-\infty}^{\infty}t|f(t)|dt)^2
But this is where I get stuck. The limits aren't equal for these two and the Cauchy Schwartz inequality is the wrong way around for them to work.
your problem statement is probably wrong, since if f(x) is even or odd, K can obviously approach 0, the inequality you want to prove need not hold in general.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 23 ·
