Using diagonalization, prove the matrix equals it's square
6 replies · 3K views
PirateFan308
Suppose that A is a 2x2 matrix with eigenvalues 0 and 1. Using diagonalization, show that A2 = A
Let [tex]A=\begin{pmatrix}a&b\\c&d\end{pmatrix}[/tex]
Av=λv where [tex]v=\begin{pmatrix}x\\y\end{pmatrix}[/tex] and x,y≠0
If λ=0 then [tex]ax+by=0[/tex] and [tex]cx+dy=0[/tex]
If λ=1 then [tex]ax+by=1[/tex] and [tex]cx+dy=1[/tex]
so Av-λv=0, then Av-λIv=0, then (A-λI)v=0. Since v≠0, then (A-λI)=0
so for λ=0 [tex]\begin{pmatrix}a&b\\c&d\end{pmatrix}[/tex] and [tex]ax+by=0[/tex] and [tex]cx+dy=0[/tex]
For λ=1 [tex]\begin{pmatrix}a-1&b\\c&d-1\end{pmatrix}[/tex] and [tex]ax-x+by=1[/tex] and [tex]cx+dy-y=1[/tex]
We must find two lin. ind. vectors such that we can create X where the first column of X is the first vector, and the second column of X is the second vector.
[tex]X^{-1}AX= \begin{pmatrix}0&0\\0&1\end{pmatrix}[/tex]
If this is true, then [tex]X^{-1}A^{2}X= \begin{pmatrix}0&0\\0&1\end{pmatrix}[/tex]
The problem is, I'm not quite sure how to prove any of this
micromass said:
You don't need to specifically find your matrix X. Only knowing that the matrix X exists would suffice. So the only thing you need is that there exists a matrix X such that
[tex]XAX^{-1}[/tex]
is diagonal. You don't need the specific form of X.
In order for the matrix X to exist, it must be invertible (it must be nxn) and since it must be able to multiply by A (2x2), X must also be 2x2.
Since there are two distinct eigenvalues, there must be two linearly independent eigenvectors. These two distinct eigenvectors can for X.
I'm still a bit confused on how to prove exactly why there must be two linearly independent eigenvectors.
You can prove this directly. If v and w are eigenvectors belonging to distinct eigenvalues, then v and w are independent. Thus if [itex]Av=\lambda v[/itex] and if [itex]Aw=\mu w[/itex] and if [itex]\lambda =\mu[/itex], then v and w are independent.
Try to prove this. Prove it by contradiction. Assume that v and w are dependent. What do you know then??
You mean "if [itex]\lambda\ne \mu[/itex]".
If v and w are dependent, then w=cv which could be put into [itex]Av=\lambda v[/itex] and [itex]Aw=\mu cv[/itex] so [itex]\lambda =\mu c[/itex] and they are dependent. But 0 and 1 are independent, so this is a contradiction.
What do you mean, 0 and 1 are independent?? 0 and 1 are numbers, not vectors. Saying that they are independent makes no sense.
