Using golf ball dimples to decrease vaccuum drag on motor vehicles and aircraft.
31 replies · 26K views
Bararontok
A golf ball without dimples experiences more drag because the deflection area of the airflow around the ball is larger which means that the pressure drop behind the golf ball is also higher. The increased drop in pressure creates a suction vacuum behind the golf ball which pulls it back and decreases its velocity and range. The dimpled golf ball on the other hand experiences less drag because the dimples create a turbulence that causes a larger surface area of the golf ball to be covered by the flowing air which decreases the size of the vacuum behind the golf ball and subsequently its drag. So if the drag reduction caused by the dimples can be used on golf balls, then why not use this technique on the bodies of motor vehicles and aircraft to increase their range and speed?
Sources: http://wings.avkids.com/Book/Sports/instructor/golf-01.html
http://www.youtube.com/watch?v=nufXpDBELdQ&feature=related
Actually, the youtube link included in my first post shows a Mythbusters experiment with a dimpled automobile and proves that the fuel economy of the automobile covered in a dimpled body rises from 26mpg to 29.65mpg which is a 14% increase in fuel economy. With such a substantial increase in fuel savings, why not modify the body of the car but using the easier to machine vortex generators since they produce the same effect as the dimples?
Airplanes don't want turbulent flow, otherwise they can stall. The dimples on a gold ball work to increase the Reynolds number of a flow that will become turbulent, effectively triggering the laminar to turbulent transition sooner. For a golf ball, this leads to a smaller effective space where turbulent flow occurs behind the ball, reducing the drag. That's my understanding, at least.
Wow, I stand corrected. I would have thought the front end of a car was so bad aerodynamically that the air would be turbulent right away.
Aesthetics, I'm sure.
Anything moving through the air is going to get turbulent flow whether it wants it or not, with only a few rare exceptions. So the key is controlling it.
The P-51 is one of the few that was designed to have completely laminar flow, but it is extrordinarily difficult to keep the surfaces smooth enough to actually keep it laminar. Plus, laminar flow is unstable, so stalls are very violent in such aircraft:
The P-51 Mustang was the first aircraft intentionally designed to use laminar flow airfoils. However, wartime NACA research data shows that Mustangs were not manufactured with a sufficient degree of surface quality to maintain much laminar flow on the wing. The RAF found that the Bell P-63, despite being designed with laminar airfoils, also was not manufactured with sufficient surface quality to have much laminar flow.
http://www.aviation-history.com/theory/lam-flow.htm
Well, partly right. Since the transition is sooner, there is more turbulent air in a dimpled ball than a smooth one. But tubulent air stays attached to the ball better, which makes the flow separation region behind the ball smaller.
In the case of a sphere, there is a sudden and dramatic drop in drag with the use of dimples for a certain Reynolds number. For low Re, dimples are worse, for high speed, dimples are better. In the case of an aerodynamic shape such as an aircraft or car, dimples do you no good - hence why they are not employed.
Im afraid this just isn't quite right - turbulence and separation (stall) are not one in the same.
Again, this is generally not true and does not work on cars. They got lucky with a freak case, I'll check out your link to see their setup better and report back.
On a related note, plasma fields for reducing drag, seems to be an active area of interest.
https://www.physicsforums.com/showthread.php?t=116408
http://defensetech.org/2006/03/30/stealths-radioactive-secret/
I haven't read up on this in quite awhile, but, IIRC, it was dismissed for stealth applications because of the associated optical effects - early testing of this concept may account for some UFO reports. But what about commercial applications? Is that still a possibility? Anyway, another thread perhaps, but it came to mind.
I just watched the clip they did with the car, wow. Are you kidding me? That is not a valid test by any stretch of the imagination. They have so much crap that the basic aerodynamic shape of the car is altered to a significant degree. All they had to do was make a two models of a car with and without dimples and stick it into a wind tunnel. Bogus test, sorry.
Why did they allow this to air on discovery channel if it is bogus? Should they not get sued for misinformation?
Mythbusters is designed for entertainment; not scientific rigor. None the less, their experiments are often designed well providing both goals can be met.
Popular Mechanics conducted a similar test with different results and explained some of the problems with the entire idea of dimples: http://www.popularmechanics.com/cars/news/4316702
It's a TV show - it's fun to watch. Based on their personalities on the show, I don't doubt their results are accuate; however, the problem is correlation does not eqaul causation (It is a poorly designed experiment with no definitive result that it was the dimples that reduced the gas milage, and not due to some other phenonemnon).
As an aside, you can't sue someone for 'misinformation.'
Another factor that I feel was over looked is body shape. A gold ball is a sphere and an airplane/car is not. The "dimple effect" ultimately comes from flow separation and where the flow separates. On a golf ball, you want flow separation as late as possible due to its circular cross section in order to reduce drag created from a difference in pressure. However, aircraft don't really much flow separation except maybe cases with large angles of attack. So the only real effect dimple will have is if they reduce the influence of surface friction which as far as I know, they don't.
Precisely.
Incidentally the study by Popular Mechanics looks at dimples that are ~5mm, while the Myth Busters looked at dimples ~75mm (just guessing, estimating 3 inches as approximately the the size of the tennis ball they used). I googled a picture of what the Fastskin's dimples look like and found this. http://www.google.com/imgres?imgurl...tx=64&ty=88&page=1&ndsp=20&ved=1t:429,r:2,s:0
I'm not saying the MythBusters got it right, although it looked reasonably convincing, but its not clear to me that the Popular Mechanics example disproves MythBusters results.
On a side note, I've seen at least one production car with vortex generators very similar to ones used on airplanes; the Mitsubishi Lancer Evolution VIII. Whether they're helpful in terms of mileage, no idea.
turp_0901_09_z+project_mitsubishi_lancer_evolution_ix_interior_exterior+vortex_generators.jpg
Bararontok said:
It is a good start.
I have no idea what this is supposed to mean or imply. :confused:
Vortex generators on cars? :) Cool idea as an aero enthusiast. As to it's usefulness in reducing drag to improve top speed performance and gas mileage? Hmmmm :).
Here's a scholarly report from Mitsubishi on the topic:
http://www.mitsubishi-motors.com/corporate/about_us/technology/review/e/pdf/2004/16E_03.pdf
They estimated for the Lancer that it reduced CD by .006. Given that car CD that I've seen listed between .30 to .25 a .006 improvement is roughly a 2% improvement. Given the velocities we drive our cars at I doubt that it could amount to much!
Exactly! And this based not only on the Reynolds number, but also on the shape. For example, the Reynolds number for a bullet is quite low, but we're not dimpling bullets for a reason, and that reason isn't that bullets are supersonic, as nearly all handgun bullets are subsonic.
Golfballs are a fairly special case, falling into that rare regime of both Reynolds number and shape where dimpling actually improves flight performance.
Interestingly, I find it odd why the wings of most birds are covered by turbulent feathers, as opposed to the beatle's fairly smooth sheets...
Hmm... I feel a study coming on...
mugaliens:
Insects versus birds: the great divide
http://www.citeulike.org/group/918/article/790560
Yes, thanks, John, and you're absolutely correct with respect to the world of micro-UAVs. They simply fly based much more in the Reynolds numbers of the birds and the bees than of anything approaching a meter or beyond. And yes, sharp leading edges and laminar flow combined with capitalizing on turbulent after-effects is the order of the day!
I have a dynamically, self-learning and stabilized helo-toy I bought for $100. I occasionally demonstrate it for guests who are leading aerospace designers, and about half of them still bite off on my story that it's the latest model in the USAF arsenal and costs $200 thousand per copy. When I show them the sales ticket and they're agahst, I remind them the iPhone, iPad and iPod Touch have the same or better sensors, for less than $300, and that the rest is simply programming, at which point they start to realize this technology no longer costs millions.
Of course some of the spouses start fingering their jewels, as they become aware their corporate income-funded riches are about to dry up.
As for me? Well, heck, I'm making a mint helping corporations figure out ways to do the same job for thousands of dollars these days that they used to pay millions of dollars for in yesteryear.
These days we're at the point where we can re-create the flight of a http://en.wikipedia.org/wiki/Entomopter" .
The key is in advancements in inertial sensors and computational (computer programming) control. Aside from these two factors, we could have done this 50 years ago.
Watch the whole episode. They did test models, both in a wind tunnel and in a water tunnel with die to look at flow. Both tests conducted at NASA JPL so they're definitely reliable. Both with positive results. In addition, they covered the car in smooth clay and tested it first. Then created the dimples and put the carved out pieces inside the car to compensate weight. They did 5 60mph 1mile long runs each, not beginning data collection until 60mph was achieved each time and stopping data collection at exactly 1 mile. Sounds like they covered all the variables to me.
If you scale up from a golf ball to a toyota prius, I'm curious how much the scale of the dimples would be to harness this...or it doesn't scale.
Are you familiar with Reynolds number and how to properly scale wind tunnel tests. It is more than likely that they didn't properly scale because the Mythbusters almost never properly scale anything.
That driving test they did with and without dimples was not even remotely close to a well controlled experiment. What if the temperature changed a little and effected the air properties, what if the wind was blowing a little faster during one test than the other, what if the driver accelerated differently or spent some of the time driving at 61mph. Are speedometers really that accurate? (I have no idea) The power required to overcome air resistance goes up with velocity cubed! So a small change in velocity from the wind or driving at a different speed can have an impact. So no, they did not cover all of the variables. They never cover all of the variables.
Well I can see your point about scale issues as well as temp. dif. and wind, etc., however the acceleration time was not included in the test. They accelerated on the reg. gas tank then switched over to their gas tank that was actually being measured when 60mph was achieved. The car was then put on cruise control for testing time. Yes there could be anomalies, but I was impressed in the testing of variable accountability. Again though, scale, wind, temp., humidity could all lead to false data... they should've used an indoor track!
I have a lot of respect for the Mythbusters guys. They have done more to interest kids in this country in science and engineering than any government program has, that's for sure. That said, nothing they do in the show should be considered scientifically sound. They do sometimes get it right and they sometimes get some good results, but rarely do they take into account all variables or do a full analysis of anything. Take it for what it is: and entertainment program with a science bent.
