Using hyperbolic substitution to solve an integral
18 replies · 4K views · last reply
Howard Fox
Two calculus exercises: (a) use cosh^2 x - sinh^2 x = 1 to find the integral of sinh^5 x dx; (b) use part (a) and a hyperbolic substitution to find the integral of x^5 / sqrt(x^2 + 9) dx.
So the question is asking to solve an integral and to use the answer of that integral to find an additional integral. With part a, I don't have much problem, but then I don't know how to apply the answer from it to part b. I know I should subsitute all the x's in part b with a trig function, right? But which one? [/B]
This is my solution for part a, I am not sure how to work on part b
Handwritten calculus working: integral of sinh^5 x dx rewritten as integral of (1 - cosh^2 x)^2 sinh x dx, substitution u = cosh x, expanded to integral of (u^4 - 2u^2 + 1) du, giving cosh^5(x)/5 - (2/3)cosh^3(x) + cosh(x) + C.
[/B]
  • Two calculus exercises: (a) use cosh^2 x - sinh^2 x = 1 to find the integral of sinh^5 x dx; (b) use part (a) and a hyperbolic substitution to find the integral of x^5 / sqrt(x^2 + 9) dx.
  • Handwritten calculus working: integral of sinh^5 x dx rewritten as integral of (1 - cosh^2 x)^2 sinh x dx, substitution u = cosh x, expanded to integral of (u^4 - 2u^2 + 1) du, giving cosh^5(x)/5 - (2/3)cosh^3(x) + cosh(x) + C.
You are replacing ##\sinh^2x## with ##1+\cosh^2x##. Check your algebra.
Also, the derivative of cosh(x) is sinh(x), not -sinh(x).
Okay, I tried to correct the previous mistakes,
Handwritten integration working: integral of sinh^5 x dx rewritten as integral of (1 - cosh^2 x)^2 sinh x dx, substitution u = cosh x, expanded to (u^4 - 2u^2 + 1) du, integrated to give cosh^5(x)/5 - 2cosh^3(x)/3 + cosh(x) + C.
Hope this one is good? Thank you
  • Handwritten integration working: integral of sinh^5 x dx rewritten as integral of (1 - cosh^2 x)^2 sinh x dx, substitution u = cosh x, expanded to (u^4 - 2u^2 + 1) du, integrated to give cosh^5(x)/5 - 2cosh^3(x)/3 + cosh(x) + C.
It is good. Look at part (a) and then look at part (b). What kind of hyperbolic substitution is worth trying in (b)?
I really don't know. I have trouble reconciling the two parts. I guess we could substitute x with asinh?
Excellent idea! What do you think ##a## ought to be? Hint: Look at the denominator.
It should be 3?
So the final integral should look something like this?
Handwritten integral of 3 sinh^5 t divided by the square root of (3 sinh^2 t + 3^2), with respect to t.
This does seem very complicated to solve though!
  • Handwritten integral of 3 sinh^5 t divided by the square root of (3 sinh^2 t + 3^2), with respect to t.
Howard Fox said:
It should be 3?
Yes.
That's because your algebra has been careless (again). Take the time to do it right. Then you will see that
(a) the denominator simplifies.
(b) you do not have a proper integral because you substituted ##1## for ##dx##.
(c) the numerator is incorrect.
kuruman said:
Yes.
Uhm, is this any better?
Handwritten math: = 3 sinh^5 U over sqrt(3 sinh^2 U + 3^2) = integral of 243 sinh^5 U over sqrt(9 sinh^2 U + 9) times 3 cosh dU.
  • Handwritten math: = 3 sinh^5 U over sqrt(3 sinh^2 U + 3^2) = integral of 243 sinh^5 U over sqrt(9 sinh^2 U + 9) times 3 cosh dU.
Much better. Now concentrate on simplifying the denominator. How could you get rid of the radical? How does one usually get rid of a radical?
Raising both denominator and numerator to the power of two?
You would do that if the expression under the radical is not a perfect square. Certainly the ##9## in the denominator is a perfect square. What about the rest? Hint: Why did you choose ##3## for the substitution ##x=3\sinh v##?
Handwritten integrand: (243 sinh^5 u) / (3 sinh u + 3) times cosh u du.
Just take the radical of the values like this?
  • Handwritten integrand: (243 sinh^5 u) / (3 sinh u + 3) times cosh u du.
kuruman said:
Absolutely not ! Is ##\sqrt{2^2+1^2}=2+1=3~##?
Okay, went back to my textbook. This should be the way to simplify the denominator, right?
Handwritten integral of 243 sinh^5(u) times cosh(u) divided by 3cosh(x), with respect to u.
  • Handwritten integral of 243 sinh^5(u) times cosh(u) divided by 3cosh(x), with respect to u.
Right, except there is more carelessness. What is your integration variable?
It was dx but then we substituted it to du, no?
