Using Moseley's Law to Calculate Kalpha2 for Lead with Z=82
  • Thread starter Thread starter mss90
    Law
The discussion revolves around using Moseley's Law to calculate the Kalpha2 energy level for lead (Z=82). The original poster mentions known Kalpha2 values for copper (Z=29) and tin (Z=50) as part of their attempt to find the corresponding value for lead.
  • Participants discuss the application of Moseley's Law and the significance of known Kalpha values for other elements in determining the Kalpha2 for lead. Questions arise regarding the constants involved in the formula and how to utilize the provided data effectively. Some participants express confusion about the relevance of Kalpha2 compared to Kalpha.
The discussion is ongoing, with various participants offering hints and suggestions. There is exploration of the relationships between the constants and the energies of different elements, as well as attempts to clarify the formula's application. Some participants are questioning their understanding and calculations, indicating a productive exchange of ideas.
Participants note potential discrepancies in their calculations and the need for clarity on the constants used in Moseley's Law. There is also mention of the original poster's confusion regarding the units of energy and the expected results.
mss90
I need to use Mosley law to find Kalpha2 for lead where Z=82
What i know is that copper (z=29) and tin (z=50) have kalpha2 of 8.03 and 25 KeV respectively
Mosley law
Could someone give me a hint please
Try a google search, using the correct spelling, Moseley's Law. You had it correct in the title line.
You'll find the formula here, and it checks out with the data you provided. http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/moseley.html
(Disclaimer. I have no idea how realistic it is to apply that formula to values of Z as high as 82.)
just use; sqrt{f} = k_1 * (Z - k_2)
f=E/h then add inn the constant and the energy but what i don't understand is how knowing those two (for Cu and Sn) can help with finding the third?
Also where can i acquire the constants? It just states;
and
are constants that depend on the type of line
thanks
I think it is all in the article I linked to. Perhaps you didn't scroll down?
By substituting Z for Cu and Sn you can confirm that the equation works and gives the energy in eV just as you require.
okay so k1=2.47*10^15 and k2 = 1 for kalpha?
How does knowing the energies for these 2 other elements help me figure it out? I am not getting this :P
Also, the question is talking about Kapha2 not just Kalpha, does that matter?
Could you please post a jpeg of the question as it's been given to you.
Okay. Here's my take on this ... and I could be wrong.
I think Moseley's Law equation is all that's called for. The difference in transition energies Kα1 and Kα2 is tiny and it suffices to use Moseley's formula as for Kα. (For an explanation of the doublets, refer to the diagram here: http://en.m.wikipedia.org/wiki/K-alpha )
Maybe the examiners didn't expect students to have memorised the constants in the formula, just the bare relationship
E = k(Z - 1)2
So, by providing you with a couple of its results, you can determine k on the spot without having memorised it. Finally, using the value of k you calculated or had memorised apply Moseley's equation for atomic number 82 and determine Kα.
Sound plausible?
E=k(Z-1)2 ó k=(Z-1)2/E
(29-1)2/8.03=97.63
(50-1)2/25 =96.04
theyr pretty close but not identical so could i just the average for K to figure out the energy for lead?
ye i saw that table as well, thanks
(29-1)2/8.03=97.63
(50-1)2/25 =96.04
That sounds like a good experimental approach.
What year of the physics course is this test paper?
E=k(Z-1)2 hence E=96.835(82-1)2 = 635334.435J its pretty high right? I am guessing its in joules
when converting I am getting 3.9654458121e+24eV doesn't compare with the table
Your post #1 indicates your working is in keV!
Ye but it still doesn't line up, right?
You haven't rearranged this correctly to isolate k.
aaah that's embarrassing, its E on top :p
E=k(Z-1)2 ó k=E/(Z-1)2
8.03 / (29-1)2=0.0102
25 / (50-1)2 =0.0104
Average = 0.0102+0.0104/2=0.0103
E=k(Z-1)2 hence E=0.0103 *(82-1)2 = 64.32KeV
