Using WolframAlpha for electrical engineering calculations
9 replies · 53K views · last reply
waht
Introduction:
WolframAlpha is a freely available computational engine that can supplement already existing software such as mathematica, maple, mathlab, or excel. The purpose of this mini-guide is to go over some of its functionality with emphasis on electrical engineering.
www.wolframalpha.com
Dimensional analysis:
WolframAlpha recognizes many common units. It will simplify dimensions and scale units. For example,
Code:
farad * henry
will generate [time]^2
Code:
0.01 uF to pF
will generate 10,000 pF or 10 nF
WolframAlpha also can tap its database to pull up a conversion formula from the context
Code:
convert 25 MHz to meters
will convert the frequency to wavelength 12 meters
Code:
find energy in 100 uF at 10 KV
will give energy in a capacitor,
or to find inductance to resonate with 10 nF capacitor at 100 Khz; just say that
Code:
find inductance for 10 nF at 100 KHz
output 253 nH
Also if you haven't memorized resistor color bands already, you can still look them up
Code:
resistor yellow purple red
output: 4.7KComplex numbers and phasors:
Working in polar form is supported in W|A. By typing an impedance in rectangular form
Code:
30 + 45i
we are quickly given its magnitude and phase of 54, and 56 degrees
and likewise, we can indicate a phasor in polar form with an exponential e
Code:
e^(i pi)
generates -1
we can also manipulate phasors algebraically
Code:
100 e^(i 45 deg) + 25 e^(i 30 deg)
output: magnitude = 124, phase = 42 deg
indicate degrees with “deg” otherwise W|A will interpret it in radians.Solving equations:
To solve [itex]x^2 - 2x + 1= 0[/itex], enter the equation as it is
Code:
x^2 - 2x + 1 = 0
output x = 1
and W|A solves it. Don't even have to specify the variable to be solved.
Solving systems of equations is just as easy,
[tex]v_1 + v_2 + v_3 = 4[/tex]
[tex]v_1 - v_2 = 10[/tex]
[tex]v_1 - 3v_2 + 5v_3 = 8[/tex]
simply type
Code:
v1 + v2 + v3 = 4, v1-v2 = 10, v1 - 3v2 + 5v3 = 8
output v1 = 23/3, v2 = -7/3, v3 = -4/3
just make sure that the equations are separated by a comma.
Differential equations are supported as well. An nth number of apostrophes indicates an nth derivative, and proceed as before. For example to solve
[tex]\frac{d^2y}{dx^2} - \frac{dy}{dx} - 2y = 0 \indent y(0) = 1, y'(0) = 2[/tex]
enter the code as follows,
Code:
y'' – y' - 2 y = 0, y(0) = 1, y'(0) = 2
and we get a solution y = e^2x as well as a plot that can be saved in pdf format, and printed out.We can also maximize and minimize
Code:
max 1 - x^2
finds maximum of 1Logic gates and boolean algebra:
Converts number bases,
Code:
binary 1111101 to hex
= 7d
We can also work with boolean expression in WolramAlpha, for example
Code:
(x or y) and (x or !y)
generates a truth table:http://img200.imageshack.us/img200/9384/truthtable.gif
a schematic with logic gates, and even simplifies the expression to a minimal form
http://img268.imageshack.us/img268/3233/scehmatic.gif
Here is the supported syntax:
Code:
NOT = !
OR = ||
AND = &&
NAND
NOR
XOR
More on calculus:
W|A can perform basic calculus
take derivatives:
[tex]\frac{d}{dt} cos(t)[/tex]
Code:
derivative cos(t)
do integration:
[tex]\int \frac{1}{x+1} dx[/tex]
Code:
integrate 1/(x+1) dx
and take Laplace and Fourier transforms:
[tex]\mathcal{L}(x^2), \mathcal{F}(e^x)[/tex]
Code:
laplace x^2
Code:
fourier  e^x
Plotting:
If you want to graph a transfer function for instance,
[tex]H(s) = \frac{s+10}{s^2 + 4s + 8}[/tex]
enter:
Code:
 graph (s + 10)/(s^2 + 4s + 8)
and here we have
http://img32.imageshack.us/img32/9715/graph.gif Conclusion:
WolframAlpha uniquely combines different tools into a one freely available package and that expands our tool box. This mini-guide doesn't cover all of W|A, it merely touches upon features that can be used in electrical engineering, for more information visit their examples page
http://www28.wolframalpha.com/examples/
also, W|A is said to expand in the future, enabling more functionality, and tools.
Thanks for putting that together, what. I've stickied this thread to help us learn how to utilize W|A.
Any further posts in this thread should be about tips on how to use W|A and its features. Discussions about W|A and its implications for eductaion, etc., belong in a different thread, like this one: https://www.physicsforums.com/showthread.php?t=307686
Resistor color codes
Code:
output: 4.7K
The inverse operation works also. Type this for input:
Code:
resistor color 4.7k ohms
... and the output is an image of the resistor with the correct color bands:
View the full W|A output here:
http://www5f.wolframalpha.com/input/?i=resistor+color+4.7k+ohms&asynchronous=false&equal=Submit
Check out the WolframAlpha app for the iPhone and iPod Touch. Its pretty awesome!
Remember when the WA app cost $50? They thought because it's better than any scientific calculator could be, they could charge that much, but you know, no one would pay that much so they made it $2.
is there any advantage over the ipod app vs the standard web version?
Would you guys recommend wolfram alpha to a student who is interested in learning more about physics and modeling physics within computing systems? I have a small bit of experience with mathlab, and am hoping to be on the go as I do this (iPad, Android, etc.)
I have "Algeo.apk" in my galaxy tab, it is a wonderful application in small scale.
