The discussion revolves around the design and structural integrity of vacuum chambers and pipes under varying pressure conditions. Participants explore calculations for wall thickness and the effects of vacuum pressure on materials, as well as safety considerations for high-pressure and vacuum systems.
- Technical explanation
- Debate/contested
- Exploratory
- One participant inquires about the vacuum pressure that a line pipe rated for 98 bar can sustain, questioning how much external pressure it can withstand when a vacuum is applied inside.
- Another participant requests a sample calculation for determining the thickness of a vacuum chamber designed to operate at 1 mbar vacuum pressure.
- Concerns are raised regarding the maximum vacuum achievable on Earth, suggesting that the question may relate to the external pressure the pipe can withstand under vacuum conditions.
- Participants discuss the need for additional information, such as the purpose of the chamber, temperature range, and whether the chamber will contain anything that contacts the wall.
- Suggestions are made regarding alternative materials and designs, including the use of plywood and plastic films to support thinner walls, emphasizing the importance of surface stability.
- One participant expresses skepticism about the wall thickness, suggesting it may deform under pressure but not fail outright.
- There is a cautionary note about the risks associated with high-pressure and vacuum systems, highlighting the forum's rules regarding assistance for dangerous activities.
Participants express varying levels of concern regarding the structural integrity of the proposed designs and the safety implications of working with high-pressure and vacuum systems. There is no consensus on the appropriate wall thickness or design parameters, and multiple viewpoints are presented.
Participants note the need for specific design parameters and conditions, such as temperature and material interactions, which are not fully addressed in the initial queries. The discussion reflects uncertainty regarding the adequacy of the proposed wall thickness for the intended vacuum conditions.
