Vacuum vessel / distiller correct wall thickness?
1 reply · 6K views · last reply
Pantera
vacuum vessel / distiller correct wall thickness??
Hello!
I have a vacuum vessel / distiller type of vessel with following:-
Temperature inside the vessel max. 200°C [celsius] and a
Vacuum at max. -80kPa = -0.8bar
Material: SS-304 = Stainless Steel
Volume = 0.654m³
My main question:
Will a 4.5mm wall thickness (SS-304) be sufficient enough?
If yes we will use as "dish ends" 2:1 Semi-ellipsoidal at 6mm THK (Thick) to compensate on the shrinkage on the dish end bend, which is about 18-20%.
OR
I have formuals for pressure vessels / dish ends only - could I use them as well and use 1 bar pressure - to be safe.
Best regards and thank you all already for your suggestions - formulas & help given.
Pantera
The wall thickness required will be dependent on the diameter of the tank.
You should not apply pressure vessel design tables to vacuum vessels because the walls of a pressure vessel are in tension, while the walls of a vacuum vessel are in compression. Buckling of a vacuum vessel wall can occur, resulting in collapse of the structure.
